Civil Engineering Association Software Software Product Autodesk Products Autodesk Point Layout 2018
 rami1976
User ID: 34597
Threads: 355
Likes: 9,524 in 1,138 posts
Given Likes: 1405
04-07-2017, 04:50 AM
[Image: 33375432814793402645.jpg]
[Image: 26809284342158773644.jpg]
Autodesk Point Layout automatically generates points from models within Autodesk® Revit®, Autodesk® AutoCAD®, and Autodesk® Navisworks® software. As you add points to the design, you embed X, Y, and Z coordinate information into your model. Each X, Y, and Z coordinate includes a unique point number and description. You can use the data you added to the model to inform the coordination process throughout the project lifecycle. Then you can export point coordinates to your compatible total station in the field so you lay out more accurate points, more quickly, reducing the risk of costly errors and delays.
[Image: tips.png]
Requires a license or free trial of an AutoCAD, Revit, or Navisworks product
  • zrilek, RajaK, amindoxiti, thanzawtun, oanm2000, Dell_Brett
  Autodesk Vehicle Tracking 2018 BennyP 3 12,167 12-02-2021, 07:42 AM
Last Post: Rycius
  Autodesk AutoCAD 2018 (x86/x64) BennyP 9 19,476 12-09-2019, 10:07 AM
  AutoDesk InfraWorks 360 Pro 2018 BennyP 1 6,800 03-10-2018, 11:15 AM
  Autodesk Inventor 2018 BennyP 5 11,246 01-26-2018, 01:13 PM
  Autodesk AutoCAD Plant 3D 2018 BennyP 1 7,669 12-18-2017, 09:32 PM
  Autodesk 3ds Max 2018 rami1976 4 9,368 10-31-2017, 09:24 PM
  AutoDesk AutoCAD Architecture 2018 (x32-x64) rami1976 3 8,846 10-31-2017, 09:12 PM
