Civil Engineering Association Software Software Product Autodesk Products Autodesk AutoCAD LT 2018 (x86/x64)
Threads: 1,118
03-22-2017, 06:50 AM (This post was last modified: 03-22-2017, 08:02 AM by BennyP. Edit Reason: N/A )
Size: 1.47 GB / 1.60 GB
[Image: 46936587685515345118.jpg]
[Image: 33734134328523653864.jpg]
Quick Summary of AutoCAD 2018:
- Xrefs now default to relative path attachment and there are a few associated tweaks including find/replace path
- You can select objects off-screen (handier than it sounds)
- You can select objects with linetypes even when selecting the gaps
- File dialogs remember settings
- A couple more dialogs can be resized
- There are a couple more tiny user interface tweaks
- The stuff from 2017.1 is included, of course
- iDrop support is gone
[Image: tips.png]
Use the 2017 KG anexed in 4shared link
[-] The following 7 users Like BennyP's post:7 users Like BennyP's post
  â€¢ camto2, rami1976, oanm2000, Wijono, Dell_Brett, Songoku, slowet
 rami1976
User ID: 34597
Threads: 355
Likes: 9,524 in 1,138 posts
Given Likes: 1388
03-22-2017, 06:57 AM (This post was last modified: 03-22-2017, 09:48 AM by rami1976.)
Autocad LT 2018 Direct links from Autodesk
_______________________________________________________________________
x64 bit link corrected
  â€¢ oanm2000, Wijono, Dell_Brett, slowet, narendra
 rami1976
User ID: 34597
Threads: 355
Given Likes: 1388
03-23-2017, 06:27 AM
Autodesk LT 2018 offline help
  â€¢ Dell_Brett, oanm2000, Songoku, slowet, narendra
 rami1976
User ID: 34597
Threads: 355
Given Likes: 1388
04-01-2017, 04:33 AM
Autodesk AutoCAD LT 2018.0.1 (X32-X64) Update
Readme
[-] The following 2 users Like rami1976's post:2 users Like rami1976's post
 rami1976
User ID: 34597
Threads: 355
Given Likes: 1388
04-26-2017, 08:03 AM (This post was last modified: 04-26-2017, 08:04 AM by rami1976.)
Autodesk AutoCAD LT 2018.0.2(X32-X64) Update
Readme
[-] The following 3 users Like rami1976's post:3 users Like rami1976's post
  â€¢ amindoxiti, Dell_Brett, oanm2000
  AutoRebar for Autodesk AutoCAD poolmand 1 12,500 08-18-2025, 09:58 AM
  Autodesk AutoCAD Civil 3D 2025 poolmand 2 5,998 12-02-2024, 01:09 PM
  Autodesk AutoCAD Plant 3D 2022 (x64) Pre-Cracked BennyP 1 10,642 10-27-2023, 04:10 PM
Last Post: Dalvisahi014
  Autodesk AutoCAD 2022 (x64) BennyP 5 13,829 03-29-2022, 11:33 AM
Last Post: Arigato
  Autodesk AutoCAD Civil 3D 2022 poolmand 2 11,711 03-13-2022, 03:04 PM
Last Post: pilitro
  Autodesk Vehicle Tracking 2018 BennyP 3 12,080 12-02-2021, 07:42 AM
Last Post: Rycius
  Autodesk AutoCAD Raster Design 2019 BennyP 5 10,907 09-22-2021, 09:07 AM
