Civil Engineering Association eBooks Journals, Papers and Presentations Scientific journals and Research papers Elastic Modulus, Poisson's Ratio, and Compressive Strength Relationships at Early Age
 xnr09
User ID: 9060
Threads: 21
Likes: 1,120 in 126 posts
Given Likes: 74
03-16-2017, 08:13 AM
Elastic Modulus, Poisson's Ratio, and Compressive Strength Relationships at Early Ages
  • Author(s): Francis A. Oluokun, Edwin G. Burdette, and J. Harold Deatherage
  • Published By: ACI Materials Journal
  • Published Year: 1991
  • Abstract: Presents the results of an experimental investigation into the relative relationships between the elastic modulus, Poisson's ratio, and the cylinder compressive strength of concrete, especially at early ages. The applicability to concrete at early ages of some of the existing relations between these properties was also researched. Tests were performed on four different concrete mixes using conventional 6 x 12 in. concrete cylinder test specimens. Test results were obtained for ages ranging from 6 hr to 28 days. Analyses of test results show that the compressive strength and the elastic modulus are related, and an increase in one is generally similarly reflected in an increase in the other. The commonly accepted relationship that the elastic modulus of concrete is proportional to the 0.5 power of the cylinder compressive strength was found to be accurate for the elastic modulus at ages 12 hr and above for all concrete mixes investigated. Poisson's ratio was found to be insensitive to both the age and the richness of the concrete mix and did not change appreciably with compressive strength development.
[-] The following 12 users Like xnr09's post:12 users Like xnr09's post
  â€¢ lisine, slowet, Dell_Brett, cace-01, temp1366, oanm2000, gulilero, faros3000, isurya, 3fan, Wijono, Ivan_1980
  Micro Structure Effect of Concrete Degradation for Compressive Strength of Concrete B TAFATNEB 0 3,875 06-03-2014, 10:24 PM
