Civil Engineering Association eBooks Codes, Manual & Handbook ACI ACI SP 79-4: Early-Age Strength Development of Concrete Incorporating Fly Ash and ...
 xnr09
User ID: 9060
Threads: 21
Likes: 1,120 in 126 posts
Given Likes: 74
02-25-2017, 12:36 PM (This post was last modified: 02-06-2024, 07:52 AM by Administrator.)
Early-Age Strength Development of Concrete Incorporating Fly Ash and Condensed Silica Fume
  • Author(s): G. Carette and V.M. Malhotra
  • Published By: ACI
  • Published Year: 5/1/1983
  • Quality: Unspecified
  • Abstract:
    ACI/ Volume: 79 Β Appears on pages(s): 765-784
    Early-age strength development of concrete in which part of the portland cement has been replaced by low-calcium fly ash tends to be slow, because fly ash acts as a relatively inert component during this period of hydration, though at later ages it contributes significantly to strength development. It was considered that the problem of low early-age strength of portland cement-fly ash concrete could be overcome by the incorporation of small amounts of condensed silica fume, a very fine and more rapidly reactive pozzolan. This report presents the results of an investigation on the early-age strength development of concrete incorporating 30% low-calcium fly ash, and to which small amounts of condensed silica fume have been added. The amounts of the fume ranged from 0 to 20% by combined weight of the portland cement plus fly ash. A total of thirty 0.06-m3 concrete mixtures with water-(cement + fly ash) ratios ranging from 0.40 to 0.80 were made; 240 cylinders were tested in compression and 180 prisms were tested in flexure. A supplementary series of six concrete mixtures was made to deter-mine the effect of silica fume and fly ash on the long-term strength development of concrete. Test data showed that the incorporation of condensed silica fume increased the compressive strength of concrete at all ages as compared with the compressive strength of the control concrete (70% portland cement + 30% fly ash). At 7 days, the loss of compressive strength due to the partial replacement of cement by fly ash was completely overcome by the addition of 10% condensed silica fume for concretes with water-(cement + fly ash) ratios ranging from 0.40 to 0.60; 15 to 20% was required for concretes with higher water-(cement + fly ash) ratios, At 28 days, regardless of the water-(cement + fly ash) ratio, the effect was generally achieved with less than 5% silica fume addition. The laterage strength development of portland cement-fly ash concrete did not appear to be impaired by the use of condensed silica fume indicating availability of sufficient lime for the fly ash pozzolanic activity.
cheers
xnr09
[-] The following 11 users Like xnr09's post:11 users Like xnr09's post
  β€’ Aviator, jfjdm, zrilek, malc, eyad, oanm2000, mgdario, Dell_Brett, ir_71, nhim4mat2006, tuanpecc1
Likes: 8,311 in 1,373 posts
Given Likes: 92
08-24-2021, 09:54 AM
ACI sp79-41 Early-Age Strength Development of Concrete Incorporating Fly Ash and Condensed Silica Fume
Author(s)/Editor(s): G. Carette and V.M. Malhotra | Size: 749 KB | Format: PDF | Quality: Unspecified | Publisher: ACI | Year: 1983 | pages: 19
[Image: 88572959016509251683.jpg]
[-] The following 11 users Like poolmand's post:11 users Like poolmand's post
  β€’ babakfeyzi, pedzaquino, PinkPant, kowheng, blaze, Dell_Brett, zrilek, mohamz, tuanpecc1, Wijono, spat
  [CivilEA Exclusive] ACI 231.1: Managing and Increasing Early-Age Strength of Low-Clinker Concrete Administrator 0 647 07-21-2026, 09:35 AM
Last Post: Administrator
  ACI SP-341: Structural Performance of Concrete Columns Incorporating Advanced Materia poolmand 0 1,517 03-04-2024, 08:01 AM
  ACI SP-314: Eco-Efficient and Sustainable Concrete Incorporating Recycled Post-Consum poolmand 0 1,691 03-04-2024, 07:34 AM
  ACI 363: Report on High-Strength Concrete Mohammad6299 1 2,696 05-07-2023, 05:28 AM
  ACI 131.3: BIM Level of Development for CIP Concrete - TechNote poolmand 0 1,638 05-02-2023, 11:18 AM
  ACI 437: Strength Evaluation of Existing Concrete Buildings poolmand 0 1,933 10-06-2021, 10:59 AM
