Civil Engineering Association Software Software Product Bentley Products WaterCAD CONNECT Edition 10.00.00.49
10-15-2016, 02:12 PM
[Image: 21263747704938683890.jpg]
Bentley Systems Inc., the leading company dedicated to providing comprehensive software solutions for sustaining infrastructure, has released the 10.00.00.40 version WaterCAD CONNECT Edition is an easy-to-use hydraulic and water quality modeling application for water distribution systems. Utilities, municipalities, and engineering fi rms trust WaterCAD as a reliable, resourcesaving, decision-support tool for their water infrastructure.
Utilities and engineering firms around the world trust WaterCAD as a reliable decision-support tool for their infrastructure. Design new water systems and manage existing water networks effectively to reduce disruption risks and energy use. WaterCAD’s ease-of-use helps you successfully plan, design, and operate water distribution systems:
- Increase capacity to adequate service levels.
- Supply clean potable water without interruption.
- Deliver high quality designs cost effectively.
WaterCAD helps you improve design productivity, with:
- Streamlined model building: Leverage and import virtually any external data format to jumpstart the model accurately, easily allocate water demands, and automate terrain extraction and node allocation.
- Organized assessment of alternatives: Assess and compare an unlimited number of physical, design, water demand, network topology, and operational scenarios.
- CAD interoperability: Model in a familiar platform, leveraging CAD tools and shortcuts when using WaterCAD from within MicroStation or AutoCAD. You can also choose to use WaterCAD as a stand-alone application, for additional flexibility.
WaterCAD is a subset of WaterGEMS. Use WaterGEMS to also run your model from within ArcGIS and for optimization modules (calibration, design, pump scheduling, pipe assessment, SCADA integration, and network simplification).
  β€’ Dell_Brett, thanzawtun, blaze, Andrew seah, PinkPant, oanm2000
 pegasso84
Ecuador
User ID: 45516
Likes: 0 in 0 posts
Given Likes: 5
11-12-2016, 08:39 PM
please add new links... because the links are down.. Thanks in advance...
  β€’
 emmi
Laos
User ID: 26
Threads: 33
Likes: 969 in 102 posts
Given Likes: 1203
12-22-2016, 10:04 PM
[Image: 36052490208043156916.jpg]
[Image: homepage.png]
[Image: comments.png]
Thanks for original uploader
[-] The following 3 users Like emmi's post:3 users Like emmi's post
  β€’ mgdario, oanm2000, Dell_Brett
  STAAD.Pro CONNECT Edition Update 3 (21.03.00.146) RajaK 7 13,365 07-27-2024, 03:40 AM
  Bentley MicroStation CONNECT Edition 2023 poolmand 2 6,527 10-08-2023, 12:24 PM
  Bentley STAAD.Pro CONNECT Edition V22 kirankumarklk 12 23,101 07-05-2023, 07:52 AM
Last Post: Arigato
  Bentley.RCDC.Connect.Edition.11.02.00.200 kirankumarklk 0 5,048 04-02-2022, 11:14 AM
Last Post: kirankumarklk
  RCDC FE Connect Edition V4 Update 1 RajaK 1 7,060 03-28-2022, 06:28 AM
  Bentley OpenRail Designer CONNECT Edition 2021 poolmand 1 4,404 02-26-2022, 09:13 AM
  Bentley OpenRoads Designer CONNECT Edition 2021 poolmand 0 4,010 02-23-2022, 10:08 AM
