Civil Engineering Association Software Software Product Autodesk Products Autodesk Structural Bridge Design 2017
10-10-2016, 08:33 AM
[Image: 37263832795006724953.jpg]
Autodesk Inc., a world leader in 3D design software for entertainment, natural resources, manufacturing, engineering, construction, and civil infrastructure, announced the release of Structural Bridge Design 2017. This software helps engineers achieve greater flexibility and efficiency in the design of small-to medium-span bridges integrating loading, analysis, and code checking processes whist providing an efficient workflow.
This single integrated software solution does not require valuable time importing, exporting or converting data instead it provides tools to help accelerate project completion.
Structural Bridge Design refines design options faster with automated updates in a define-analyse-code check loop whenever parameters change.
Engineers can additionally improve accuracy and reliability by reviewing code check requirements with detailed β€œhand” calculation-style design sheets that are created will full formulae and code referencing.
With Structural Bridge Design, users can deliver design reports faster using more accurate, reliable, consistent and verifiable data throughout the project lifecycle. These reports provide an understanding of engineering calculations involved to help maintain consistency and context throughout the project lifecycle.
To provide better understanding, the software creates side-by-side graphical displays of the data and results produced in the reports at all stages of analysis and design to offer further understanding of the results.
The design sections and bridge beams that are available within the software are based on a variety of international standards – including Eurocodes, AASHTO LRFD, British Standards as well Australian and New Zealand Standards. This allows users to create and develop their small-to-medium span bridges using required international standards before construction has commenced.
The functionality of Structural Bridge Design software can be simply broken down into three specific areas including:
- Section plan which deals with design on a section by section basis
- Girder design which works with the whole length of the girder
- Bridge Structure loading and analysis
Employing Autodesk Structural Bridge Design on your business’s projects will allow you to save time and money by utilising the tools available within the software.
[Image: comments.png]
Product: Autodesk Structural Bridge Design
Version: 2017
Supported Architectures: 32bit
Language: english
System Requirements: PC
Supported Operating Systems: Windows 7even / 8.x / 10
[-] The following 13 users Like TAFATNEB's post:13 users Like TAFATNEB's post
  β€’ PinkPant, blaze, oanm2000, temp1366, bridgeengineer, mgdario, Dell_Brett, cace-01, slowet, Rodmo376, bluefish80, piyush86, Hengki
 rami1976
User ID: 34597
Threads: 355
Likes: 9,524 in 1,138 posts
Given Likes: 1405
03-19-2017, 09:46 PM
Direct Link for trial version from autodesk
  β€’ Dell_Brett, ali akbar, blaze, jfjdm, oanm2000, cace-01
 hmwere
Uganda
User ID: 17377
Threads: 93
Likes: 421 in 152 posts
Given Likes: 1475
03-31-2017, 09:42 AM
Request for only autodesk-2017-key-generator-x32 bit download link. (especially for this bridge software)
Thanks and regards
  β€’
Threads: 1,118
03-31-2017, 10:00 AM
The key generators for 2017 were posted here and the links are alive.
Now tell me, you ask without searching, you ask for another special key generator only for your bridge software or you simply post a useless post and try to receive a warning ?
  β€’ hmwere, Aviator, oanm2000, cace-01
  Autodesk Structural Bridge Design 2024-32bit X86.ISO TAFATNEB 0 4,665 04-13-2023, 07:37 AM
  Autodesk Structural Bridge Design 2022 poolmand 0 4,314 11-01-2021, 08:06 AM
  Autodesk Structural Bridge Design 2018 (X32) BennyP 1 6,293 10-16-2017, 06:41 AM
  Autodesk Revit 2017 Add-Ins exclusive To Autodesk Subscription Customers bus001 0 5,165 03-03-2017, 11:05 AM
Last Post: bus001
  AutoDesk InfraWorks 360 2017.3 TAFATNEB 2 6,550 03-01-2017, 01:35 PM
  Autodesk Revit 2017.1.1 TAFATNEB 0 5,298 12-19-2016, 07:26 AM
  Autodesk AutoCAD 2017.1.1 TAFATNEB 1 7,187 12-18-2016, 04:58 AM
