Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS 4449:2005+A3:2016
 yakwetu
User ID: 1947
Threads: 43
Likes: 1,240 in 130 posts
Given Likes: 154
05-13-2016, 10:18 PM
BS 4449:2005+A3:2016 Steel for the reinforcement of concrete. Weldable reinforcing steel. Bar, coil and decoiled product. Specification
  • Author(s): BSI
  • Published By: BSI
  • Published Year: 2005
  • Size: 1 MB
  • Quality: Original preprint
  • Abstract: BS 4449 is intended for manufacturers, fabricators and purchasers of ribbed reinforcing steel (bars, coils and decoiled products) for the reinforcement of concrete structures. It provides designations based on the grade of steel, the product form and dimensions. The standard is used to specify all normal technical requirements for reinforcing steels, including chemical analysis, mechanical properties, rib geometry and tolerances on dimensions.
[-] The following 16 users Like yakwetu's post:16 users Like yakwetu's post
  â€¢ Dell_Brett, malc, Jackass, sodapas, abualamal, zrilek, f_slikken, PinkPant, blaze, oanm2000, melekeen, Rami11, Trishu999, peixoto, andersen3, Batman07
  BS 4449:2005+A2:2009 Steel for the reinforcement of concrete — Weldable reinfor... portal61 4 4,589 09-16-2014, 12:20 PM
  BS 4449:1997+A1 Specification for Carbon steel bars for the reinforcement of concrete ir_71 3 4,363 05-15-2014, 07:52 AM
