Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Theses, Journals and Papers Request [REQUEST] Cyclic testing of steel column-tree moment connections with various beam splice lengt
[Request] Cyclic testing of steel column-tree moment connections with various beam splice lengt
 temp1366
User ID: 85519
Threads: 80
Likes: 1,544 in 165 posts
Given Likes: 742
05-10-2016, 04:54 PM
  • Article/eBook Full Name: Cyclic testing of steel column-tree moment connections with various beam splice lengths
  • Author(s): Lee, Kangmin; Li, Rui; Chen, Liuyi; Oh, Keunyeong; Kim, Kang-Seok;
  • Publish Date: 2014
  • Published By: koreascience
  • Related Links:
  â€¢
  [REQUEST] Cyclic testing of weak-axis column-tree connections with formation of plastic hinge a temp1366 0 1,457 05-10-2016, 04:52 PM
Last Post: temp1366
  [REQUEST] Rotation Capacity Evaluation of Column-Tree Type Steel Moment Connection with Bolt-Sl temp1366 0 1,582 05-10-2016, 04:50 PM
Last Post: temp1366
  [REQUEST] Cyclic testing of steel column-tree moment connections with various beam splice lengt temp1366 0 1,510 05-10-2016, 04:48 PM
Last Post: temp1366
  [REQUEST] Connections Between Steel Frames and Concrete Walls inge911 0 1,641 12-19-2015, 03:55 PM
Last Post: inge911
