Civil Engineering Association Software Software Product Autodesk Products Autodesk Advance Steel 2017 (x64)
Threads: 1,118
03-25-2016, 09:56 AM
[Image: 04128099554636707719.gif]
[Image: 81641579199346860037.gif]
Complete toolset for structural steel design
Advance Steel detailing software for structural steel design provides engineering and detailing professionals with tools for structural engineering.
[-] The following 27 users Like BennyP's post:27 users Like BennyP's post
  â€¢ zrilek, temp1366, TAFATNEB, PinkPant, jcbv, stosto6666, oanm2000, telecivil, malc, jonny78, cordoba123, Rodmo376, dizz, Dell_Brett, aema, dovsky, monter, rodleyzed, caifan, dquan373, andiengineering, subin91, mgdario, oreslaw, gabe, raymelito, stldtls
 temp1366
User ID: 85519
Threads: 80
Likes: 1,544 in 165 posts
Given Likes: 742
05-02-2016, 08:06 AM
Robot-AdvanceSteel Link 2017
With Robot-AdvanceSteel Link, you can export a Robot structural model using the smlx format. You can then import the smlx file in Advance Steel in order to detail steel connections and automatically generate fabrication documents. From Robot, you can export values of internal forces with the model to the smlx file. After importing the file to Advance Steel, you can use these values to perform code checking of connections.
Conversely, you can export a model from Advance Steel in order to perform structural analysis and code checking in Robot.
You can also track changes in the same model in both applications using the synchronization feature.
[Image: homepage.png]
[-] The following 8 users Like temp1366's post:8 users Like temp1366's post
  â€¢ jcbv, PinkPant, oanm2000, zrilek, malc, Dell_Brett, cace-01, mgdario
Threads: 1,118
05-09-2016, 03:41 PM
Product Key
Autodesk Advance Steel 2017 959I1
[-] The following 10 users Like BennyP's post:10 users Like BennyP's post
  â€¢ cace-01, zrilek, Dell_Brett, malc, dquan373, concreteok, PinkPant, oreslaw, gabe, aema
  Autodesk Advance steel 2026 rami1976 0 4,661 06-04-2025, 09:45 PM
  Autodesk Advance Steel 2019 ML rami1976 1 5,566 04-13-2018, 01:51 PM
  AutoDesk Advance Steel 2018 rami1976 1 7,491 04-07-2017, 04:55 AM
  Autodesk Structural Bridge Design 2017 TAFATNEB 3 9,881 03-31-2017, 10:00 AM
  Autodesk Revit 2017 Add-Ins exclusive To Autodesk Subscription Customers bus001 0 5,165 03-03-2017, 11:05 AM
Last Post: bus001
  AutoDesk InfraWorks 360 2017.3 TAFATNEB 2 6,550 03-01-2017, 01:35 PM
  Autodesk Revit 2017.1.1 TAFATNEB 0 5,298 12-19-2016, 07:26 AM
