Civil Engineering Association eBooks Codes, Manual & Handbook Non-English written codes VENEZUELA - Seismic design of metallic tanks.
 anfaga
structural engineer
User ID: 12412
Threads: 40
Likes: 606 in 50 posts
Given Likes: 279
01-05-2016, 03:32 PM
Author(s)/Editor(s): Covenin. | Size: 6,51 MB | Format: PDF | Quality: Scanner | Publisher: Fondonorma. | Year: 2000 | pages: 32
[Image: 24666874314191984047.jpg]
This standard applies Venezuelan seismic analysis of industrial plants - oil and non-oil companies- such as cantilevered structures on the basis of reinforced concrete or steel, vertical vessels supported on a skirt or a support structure, fireplaces, furnaces, towers , silos and other facilities of similar configuration, essentially horizontal structures on foundations, columns or walls of reinforced concrete or steel drums, heat exchangers, pipe bridges, fields, air coolers.
This Standard should be used in conjunction with COVENIN 3621 code.
For application to a particular installation, it is required to know the geographical location, the degree of risk and the geotechnical characteristics of the site foundation.
[-] The following 10 users Like anfaga's post:10 users Like anfaga's post
  â€¢ jcbv, ssobhan, blaze, oanm2000, aema, Dell_Brett, PinkPant, bridgeengineer, heogay43, rizal13
  VENEZUELA - Seismic design of industrial installations. anfaga 0 3,661 01-12-2016, 01:00 PM
Last Post: anfaga
  VENEZUELA - LRFD steel design code. anfaga 0 3,556 11-30-2015, 11:37 AM
Last Post: anfaga
  VENEZUELA - Design and construction of structural concrete code. anfaga 0 3,698 11-29-2015, 09:59 PM
Last Post: anfaga
  VENEZUELA - Criteria and minimum action code. anfaga 0 3,306 11-26-2015, 12:54 PM
Last Post: anfaga
  VENEZUELA - Wind actions on structures code. anfaga 0 2,973 11-26-2015, 12:46 PM
Last Post: anfaga
  VENEZUELA - Seismic code. anfaga 0 3,579 11-21-2015, 08:32 PM
Last Post: anfaga
