Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Theses, Journals and Papers Request [REQUEST] Connections Between Steel Frames and Concrete Walls
[Request] Connections Between Steel Frames and Concrete Walls
Away  inge911
China
User ID: 53261
Threads: 6
Likes: 296 in 21 posts
Given Likes: 519
12-19-2015, 03:55 PM
  • Article/eBook Full Name:
  • Connections Between Steel Frames and Concrete Walls
  • Author(s):
  • Author: Roeder, Charles W.; Hawkins, Neil M.
  • Published By:
  • AISC
  • Related Links:
  • Code:
[-] The following 2 users Like inge911's post:2 users Like inge911's post
  â€¢ pezhmankhan, temp1366
  [REQUEST] Cyclic testing of steel column-tree moment connections with various beam splice lengt temp1366 0 1,386 05-10-2016, 04:54 PM
Last Post: temp1366
  [REQUEST] Cyclic testing of steel column-tree moment connections with various beam splice lengt temp1366 0 1,496 05-10-2016, 04:48 PM
Last Post: temp1366
