Civil Engineering Association Software Software Product Non Engineering Software PDF Eraser Pro 1.4.0.0 DC 19.08.2015 Portable
 er.shyams
Member
United Kingdom
User ID: 36991
Threads: 45
Likes: 966 in 83 posts
Given Likes: 783
08-20-2015, 08:49 AM
[Image: 14638340428553851535.jpeg]
PDF Eraser is a Windows application that deletes and erases text, images, logos and all unnecessary objects from PDF files. Users can use the program to remove some original content from a PDF file, and then add their text and images. Besides that, PDF Eraser has a built-in PDF Page Cutter, which allows users to delete unnecessary PDF pages. Considering lots of scanned PDF documents, PDF Eraser also added the PDF Rotating function rotates PDF pages properly with 2 clicks.
Main Features:
- Delete PDF Text Easily
- Erase PDF Images or Logos
- Add Your Text to PDF
- Place Your Images to PDF
- Cut PDF Pages
- Customize Eraser Size
WHAT CAN PDF ERASER DO
- If you got a PDF document contains unwanted text and images, you can use PDF Eraser to erase them and save to a new PDF file.
- Erasing is not the only thing PDF Eraser can do. You can use the program to add your own text and pictures into the PDF as well.
- PDF Eraser can rotate the PDF pages also. It will help you to rotate the PDF pages to the correct orientation.
- You might find some PDF pages are unnecessary, so you can use the built-in PDF Page Cutter to delete unwanted pages.
OS : Windows XP, Vista, 7 and 8
Language : English
[Image: homepage.png]
[-] The following 21 users Like er.shyams's post:21 users Like er.shyams's post
  • PinkPant, ska51, Dell_Brett, slowet, K.Lee, oanm2000, thanzawtun, Rodmo376, dquan373, emmi, ranger, malc, learner20, dovsky, ykhackhack, daywalker, promo8, tolesa54, monter, mosesgrace, jayborre
