Civil Engineering Association eBooks Journals, Papers and Presentations Propagating Waves in the Steel, Moment-Frame Factor Building Recorded during Earthqua
07-03-2015, 09:57 PM
Propagating Waves in the Steel, Moment-Frame Factor Building Recorded during Earthquakes
Author: Monica D. Kohler, Thomas H. Heaton, and Samuel C. Bradford | Size: 2.6 MB | Format: PDF | Quality: Unspecified | Publisher: Bulletin of the Seismological Society of America, Vol. 97, No. 4, pp. 1334–1345, August 2007, doi: 10.1785/0120060148 | Year: 2007 | pages: 13
Abstract Wave-propagation effects can be useful in determining the system identification of buildings such as the densely instrumented University of California, Los Angeles, Factor building. Waveform data from the 72-channel array in the 17-story moment-resisting steel frame Factor building are used in comparison with finite element calculations for predictive behavior. The high dynamic range of the 24-bit digitizers allows both strong motions and ambient vibrations to be recorded withreasonable signal-to-noise ratios. A three-dimensional model of the Factor building has been developed based on structural drawings. Observed displacements for 20 small and moderate, local and regional earthquakes were used to compute the impulse response functions of the building by deconvolving the subbasement records as representative input motions at its base. The impulse response functions were then stacked to bring out wave-propagation effects more clearly. The stacked data are used as input into theoretical dynamic analysis simulations of the building’s response.
[Image: comments.png]
  β€’ f_slikken, PinkPant, jcbv, oanm2000, zrilek, K.Lee
  Seismic Design of Steel Special Moment Frames: A Guide for Practicing Engineers yanburak 2 8,736 08-04-2021, 08:44 PM
Last Post: Wijono
  Retrofitting steel special moment frame using ADAS metallic yielding dampers TAFATNEB 0 5,190 12-28-2014, 08:45 AM
  Seismic Demands on Steel Braced Frame Buildings with Buckling-Restrained Braces TAFATNEB 0 6,337 10-08-2014, 02:06 PM
  Evaluation of Egyptian code provisions for seismic design of moment-resisting-frame m TAFATNEB 0 5,255 09-05-2014, 02:03 PM
  Reliability Analysis of Steel Building Frame Under Earthquake Forces TAFATNEB 0 4,243 05-09-2014, 10:56 AM
  Seismic Demands on Steel Braced Frame Buildings with Buckling-Restrained Braces TAFATNEB 1 5,622 11-28-2013, 12:06 PM
  HOW HAVE CHANGES IN BUILDING CODE PROVISIONS FOR REINFORCED CONCRETE FRAME STRUCTURES TAFATNEB 0 5,343 11-23-2013, 11:45 PM
