Civil Engineering Association eBooks Journals, Papers and Presentations Performance based earthquake design using the CPT
 PinkPant
Turkey
User ID: 25448
Threads: 67
Likes: 4,007 in 374 posts
Given Likes: 10354
05-14-2015, 08:17 AM
Author: P.K. Robertson | Size: 867 KB | Format: PDF | Quality: Unspecified | Year: 2009 | pages: 21
Application of the Cone Penetration Test (CPT) for the evaluation of seismic performance isreviewed and updates presented. The role of the CPT in geotechnical earthquake engineering is presented.The use of the CPT to identify soil behavior type and the normalization of CPT parameters is also reviewedand updates presented. The case-history based method to evaluate the resistance of sand-like soils to cyclicloading is reviewed and compared with the expanded and re-evaluated case history database. The laboratory based method to evaluate the resistance of clay-like soils to cyclic loading is reviewed and modified for appli-cation using the CPT. A new combined CPT-based method to evaluate the resistance to cyclic loading is pro- posed that covers all soils and is evaluated using an expanded case history database. The CPT-based methodis extended to estimate both volumetric and shear strains for all soils and evaluated using the expanded casehistory database
[-] The following 14 users Like PinkPant's post:14 users Like PinkPant's post
  â€¢ blaze, slowet, cace-01, Dell_Brett, f_slikken, zrilek, oanm2000, Jackass, gulilero, amindoxiti, malc, bridgeengineer, civilgen, rizal13
  Performance-based seismic assessment of skewed bridges bridgeengineer 0 5,410 04-22-2016, 06:31 AM
Last Post: bridgeengineer
  Performance –Based Design emmi 2 8,122 03-24-2015, 10:10 AM
Last Post: ssobhan
  Performance of buildings during the 2001 Bhuj earthquake TAFATNEB 0 4,287 05-10-2014, 10:32 AM
  Performance of elevated tanks in Mw 7.7 Bhuj earthquake of January 26th, 2001 TAFATNEB 0 3,862 05-10-2014, 08:09 AM
  Performance Based Earthquake Engineer ing: Application to an Actual Bridge-Foundation TAFATNEB 0 4,206 05-03-2014, 09:06 AM
  1 BUILDING PERFORMANCE IN THE BOUM ERDES, ALGERIA, EARTHQUAKE OF MAY 21, 2003 TAFATNEB 0 4,072 04-26-2014, 01:15 PM
  PUSHOVER ANALYSIS FOR PERFORMANCE BASED-SEISMIC DESIGN OF RC FRAMES WITH SHEAR WALLS TAFATNEB 0 5,309 04-11-2014, 09:13 AM
