Civil Engineering Association eBooks Structural Books Concrete Tall Buildings - Structural design of concrete buildings up to 300 m tall
 RyanRS
Indonesia
User ID: 32427
Threads: 175
Likes: 4,684 in 228 posts
Given Likes: 765
04-19-2015, 01:44 AM
Size: 3.22 MB | Format: PDF | Quality: Original preprint | Publisher: the fib and MPA The Concrete Centre (UK) | Year: 2014 | pages: 164 | ISBN: 978-2-88394-113-7
[Image: 29913290857459851241.png]
fib Bulletin No. 73
Abstract:
fib Bulletin 73: Tall Buildings is the result of a collaboration between the fib and MPA The Concrete Centre (UK).
Task Group 1.6 High-rise buildings, within fib Commission 1: Structures, was drawn together with a mandate to write about the experience and know-how pertinent to the development, design and construction of tall concrete buildings. The group’s findings are presented in this state-of the-art report.
Tall buildings are a unique challenge to engineers, even to those with extensive experience of low-rise structures. The bulletin explains the critical interfaces with other professionals, for example architects, building services engineers, faΓ§ade and lift specialists, geotechnical engineers and wind specialists, highlighting how these parties interact with engineers and can influence and guide the development of the structural solution.
The key factors in choosing the most appropriate structural system are discussed. The bulletin covers the criteria used to select the most economical structural elements including the foundations, the vertical elements and the floor slabs. Examples of common construction methods are presented and their effects on the structural engineering design are discussed. Tall buildings can undergo significant deformation during their construction and service life. These movements need to be understood by the designer and potentially compensated for in the design and during construction.
One of the main particularities of the design of tall buildings is the dominance of the lateral loading from wind and seismic actions. The bulletin provides a discussion of these important topics and sets out the current approach taken by experienced engineers. Designers of tall buildings also need to understand the dynamic behaviour of the structure and confine the motion of the building to within acceptable limits. Approaches to damping and dynamic performance are discussed and guidance provided on the appropriate occupant comfort limits.
[-] The following 44 users Like RyanRS's post:44 users Like RyanRS's post
  β€’ amindoxiti, gianniorlati, malc, ASEC, aslam, malee, pezhmankhan, titko, Veggeta, junaid, concreteok, avscorreia, manzoor_quadri, TAFATNEB, cace-01, zrilek, ykhackhack, vvvv, Dell_Brett, dinu69in, apocalipse, oreslaw, oanm2000, miquan, ssobhan, faros3000, viet2010, Trishu999, melekeen, warbeast, bigone, paulocs, promo8, yutt, bridgeengineer, scorpion07, chairatpk, rcnet, psk62, jayborre, lisine, Rodmo376, moh_towhid, civilgen
 titko
User ID: 10598
Threads: 15
Likes: 522 in 69 posts
Given Likes: 241
04-19-2015, 05:18 AM
[-] The following 22 users Like titko's post:22 users Like titko's post
  β€’ junaid, blaze, subin91, Williams, manzoor_quadri, TAFATNEB, ykhackhack, Dell_Brett, oanm2000, GMianG, Jackass, chenamoy, albani, techno, cristi, gulilero, ashcivilea, bigone, engrasad, nickycruz, faros3000, Aransam
 junaid
User ID: 402
Threads: 197
Likes: 8,170 in 732 posts
Given Likes: 983
04-19-2015, 06:25 AM
[-] The following 30 users Like junaid's post:30 users Like junaid's post
  β€’ jcbv, Williams, vardan, highcivil, rezart, manzoor_quadri, TAFATNEB, ykhackhack, Dell_Brett, oanm2000, ssobhan, titko, Andrew seah, carolinandra, PinkPant, simanta, mgdario, warbeast, ashcivilea, bigone, ruaumoko, draluka, icmrb7777, tomtumx, agarciam2, ibg0203, bridgeengineer, Aransam, lisine, Sumatra
  Design and Detailing of Low-Rise Reinforced Concrete Buildings Base on ACI318-14 poolmand 1 3,854 10-14-2024, 07:54 AM
  Seismic Retrofit of Existing Reinforced Concrete Buildings carolinandra 0 3,280 02-05-2023, 08:00 PM
Last Post: carolinandra
  Illustrated Design of Reinforced Concrete Buildings (Design of G+3 Storeyed Buildings poolmand 3 5,322 12-29-2022, 06:01 AM
Last Post: amaranu
  Guidelines for the Simplified Design of Structural Reinforced Concrete for Buildings killoobilloo 3 6,697 12-28-2022, 09:55 PM
  FIB 43: Structural connections for precast concrete buildings oscargon 2 3,453 08-22-2022, 04:10 PM
Last Post: Dell_Brett
  Structural connections for precast concrete buildings Ernest0 2 2,854 08-22-2022, 04:06 PM
  Concrete Buildings in Seismic Regions cace-01 10 5,361 01-20-2022, 01:05 PM
Last Post: cace-01
