Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) EN 14188-1:2004 Joint fillers and sealants - Part 1: Specifications for hot applied s
01-16-2015, 05:15 PM (This post was last modified: 01-16-2015, 05:23 PM by ir_71.)
EN 14188-1:2004 Joint fillers and sealants - Part 1: Specifications for hot applied sealants
Author: CEN/TC 227 | Size: 1 MB | Format: PDF | Quality: Original preprint | Publisher: CEN | Year: 2004 | pages: 20
[Image: 04501016109532141602.jpg]
This document specifies requirements for hot-applied normal and fuel resistant joint sealants to be used in roads, airfields and other trafficked areas. The specification also applies to hot-applied normal joint sealants in bituminous surfacing and between bituminous surfacing and concrete pavements.
EN 14188-2:2004 Joint fillers and sealants - Part 1: Specifications for hot applied sealants
Author: CEN/TC 227 | Size: 0.92 MB | Format: PDF | Quality: Original preprint | Publisher: CEN | Year: 2004 | pages: 20
[Image: 77904805616267250344.jpg]
This document specifies the requirements for cold applied normal and fuel resistant joint sealants for concrete pavements to be used in roads, parking decks, bridge decks, airfields and other trafficked areas.
This document does not cover the use in gasoline stations, jet fuel stations on airfields and the chemical industry.
  â€¢ bridgeengineer, junaid, Dell_Brett, zrilek, f_slikken, dinu69in, malc, blaze, Mohammad6299
01-17-2015, 06:56 AM
EN 14188-3:2006 Joint fillers and sealants - Part 3: Specifications for preformed joint seals
Author: CEN/TC 227 | Size: 0,5 MB | Format: PDF | Quality: Original preprint | Publisher: CEN | Year: 2006 | pages: 19
[Image: 63535554433706125161.jpg]
This European Standard specifies requirements for preformed joint seals made of vulcanised rubber for concrete pavements.
General requirements for finished joint seals are also given. This European Standard is applicable to joint seals for joints in new concrete pavements and maintenance work in concrete highways.
  â€¢ zrilek, blaze, junaid, PinkPant, malc, Mohammad6299, amindoxiti, Dell_Brett, bridgeengineer, peixoto
 Mohammad6299
User ID: 42302
Threads: 251
Likes: 7,913 in 854 posts
Given Likes: 4212
01-18-2015, 09:07 AM
BS EN 14188 - Joint fillers and sealants - Parts 1-4
[-] The following 8 users Like Mohammad6299's post:8 users Like Mohammad6299's post
  â€¢ amindoxiti, junaid, zrilek, oanm2000, Trishu999, bridgeengineer, PinkPant, peixoto
  BS 5212 Cold applied joint sealant systems for concrete pavements ir_71 3 3,435 03-21-2015, 05:46 PM
Last Post: junaid
  BS EN 806 part 1 to 4 Specifications for installations inside buildings conveying wat mybest 5 3,983 03-06-2015, 05:15 AM
Last Post: Veggeta
  BS EN 1708-1:2010 Welding — Basic welded joint details in steel Part 1: Pressurized c ir_71 1 2,552 02-19-2013, 02:20 PM
  BS 2499 Hot-applied joint sealant systems for concrete pavements ir_71 1 2,444 02-14-2013, 10:50 AM
  PD 8010-1:2004 Code of practice for pipelines — Part 1: Steel pipelines on land ir_71 1 2,939 10-07-2012, 05:01 AM
  PD 8010-2:2004 Code of practice for pipelines - Part 2: Subsea pipelines ir_71 1 3,175 10-07-2012, 04:51 AM
  BS EN 10305 part 1 to part 6- Steel tubes for precision applications mybest 0 2,119 11-28-2011, 06:48 AM
Last Post: mybest
