Civil Engineering Association eBooks Structural Books Steel SCI P212: Joints in Steel Construction - Simple Connections
 vinnunsam
User ID: 3932
Threads: 34
Likes: 1,281 in 116 posts
Given Likes: 457
#11
02-19-2014, 06:21 AM
Another Mirror Link to download "SCI P212 - 2002"
This publication is one of a series of "Green Books" that cover a range of steelwork connections. It provides design guidance for structural steelwork connections for use in buildings designed by the "Simple Method" i.e. braced frames where connections carry mainly shear and axial loads only.
Other books in the series are:
Joints in steel construction: Moment connections (P207/95), which provides design guidance for connections which in addition to shear and axial loads, are required to resist bending moments.
Joints in steel construction: Composite connections (P213/98), which provides design guidance for moment resisting composite end plate connections.
Design guidance for a range of simple connections was originally published in two separate volumes entitled Joints in simple construction: Volume 1: Design Methods (P205) and Volume 2: Practical Applications (P206/92). Availability of further research has enabled this publication to include design guidance for a wider range of simple joints and, at the same time, the opportunity has been taken to combine the two volumes.
[Image: 10725239557943839025.jpg]
[-] The following 14 users Like vinnunsam's post:14 users Like vinnunsam's post
  â€¢ malc, PinkPant, jcbv, warbeast, Andrew seah, Jackass, seriousboy, vardan, Dell_Brett, Hengki, nickycruz, zrilek, usman, febo927
Pages (2): « Previous 1 2
  Behaviour and Design of Steel and Composite Connections in Fire carolinandra 0 3,427 01-10-2023, 12:16 AM
Last Post: carolinandra
  ECCS - European Recommendations for the Design of Simple Joints in Steel Structures agelos100 0 2,023 05-14-2020, 09:19 AM
Last Post: agelos100
  Design of Joints in Steel and Composite Structures amindoxiti 3 4,023 12-17-2019, 06:53 AM
  Architecturally Exposed Structural Steel: Specifications, Connections, Details carolinandra 0 2,028 01-25-2019, 11:06 AM
  Design and Analysis of Connections in Steel Structures: Fundamentals and Examples amindoxiti 1 2,824 12-16-2018, 07:54 AM
Last Post: malee
  Proceedings of the Workshop on Connections in Steel Structures Flexi 4 5,272 06-14-2018, 01:14 PM
Last Post: gulilero
  SCI P101: Curtain wall connections to steel frames ir_71 3 4,142 02-27-2016, 04:51 AM
Last Post: cabpcabp
