Civil Engineering Association eBooks Structural Books Bridge (Project and Technology) TXDOT: Bridge Detailing Manual
 niki102
User ID: 8143
Threads: 82
Likes: 2,495 in 189 posts
Given Likes: 845
10-21-2009, 03:01 AM (This post was last modified: 12-16-2011, 08:59 PM by usman.)
Bridge Detailing Manual, Aug-2001
[Image: ge5y0jgekompho3qfw4.bmp]
Info:
This manual provides general guidelines for use by bridge designers and technicians. It is intended neither to be all inclusive, nor to replace the judgment of the design engineers or detailers. All details are provided as examples only and are not intended to accurately reflect any particular structure. The conventions provided within this manual should assist in producing consistent plans.
The manual will be added to and updated on a periodic basis. Any errors or recommendations should be forwarded to the Director of Bridge Design.
The information in this manual is based on American Association of State Highway and Transportation Officials (AASHTO ) Standard and Interim Specifications that have been modified to incorporate Bridge Division standard practices.
Content:
Chapter 1: General Information [ Section 1 - Overview ~ Section 2 - Definitions ~ Section 3 - County/District Information ~ Section 4 - Useful Information ~ Section 5 - Detailing Information ~ Section 6 - Reinforcing Steel ~ Section 7 - Foundations ]
Chapter 2: Layouts and Estimated Quantities [ Section 1 - General Information ~ Section 2 - Proper Titles for Bridge Layouts ~ Section 3 - Layout Sheets ~ Section 4 - Bridge Layout Sheet Checklist ~ Section 5 - Normal Parameters ~ Section 6 - Plan View ~ Section 7 - Elevation View ~ Section 8 - Test Hole/Boring Details ~ Section 9 - Typical Transverse Section ~ Section 10 - Title Block ~ Section 11 - Estimated Quantities Sheet ~ Section 12 - Table of Estimated Quantities ~ Section 13 - Bearing Seat Elevations ]
Chapter 3: Abutments [ Section 1 - General Information ~ Section 2 - Abutment Sheet ~ Section 3 - Sheet Checklist ~ Section 4 - Normal Parameters and Calculations ~ Section 5 - Plan View ~ Section 6 - Elevation View ~ Section 7 - Main Section Details ~ Section 8 - Wingwall Details ~ Section 9 - Corner Details ~ Section 10 - Bar Details ~ Section 11 - Miscellaneous Details ]
Chapter 4: Interior Bents [ Section 1 - General Information ~ Section 2 - Simple Interior Bent Sheets ~ Section 3 - Sheet Checklist ~ Section 4 - Normal Parameters ~ Section 5 - Simple Interior Bent ~ Section 6 - Inverted-T Cap Details ~ Section A-A Example ~ Section 7 - Wall Details ~ Section 8 - Bar Details ~ Section 9 - Miscellaneous Details ]
Chapter 5: Prestressed Concrete Beam Spans [ Section 1 - General Information ~ Section 2 - Prestressed Concrete Beam Span Sheets ~ Section 3 - Sheet Checklist ~ Section 4 - Normal Parameters ~ Section 5 - Prestressed I-Beam Spans ~ Section 6 - Curve Information ~ Section 7 - Miscellaneous Slab Information ~ Section 8 - Beam Haunch ~ Section 9 - Typical Reinforcing ~ Section 10 - Beam Types and Dimensions ~ Section 11 - Miscellaneous Details ]
Chapter 6: Structural Steel [ Section 1 - General Information ~ Section 2 - Continuous Steel Beam/Plate Girder Units ~ Section 3 - Steel Beam Superstructure Checklist ~ Section 4 - Steel Girder Superstructure Checklist ~ Section 5 - Typical Transverse/Radial Section ~ Section 6 - Special Notes ~ Section 7 - Common Plate and Shape Designations ~ Section 8 - Connection Details ~ Section 9 - Substructure and Bearings ~ Section 10 - Miscellaneous Details ]
Download Links:
7.6 MB - 225 pages
[-] The following 36 users Like niki102's post:36 users Like niki102's post
  β€’ timosiβ„’, timosiβ„’, kowheng, kowheng, abudabeeja, abudabeeja, albert23rd, albert23rd, junaid, junaid, leithowsky, leithowsky, Grunf, Grunf, struceng, struceng, Dell_Brett, Dell_Brett, bybyby, bybyby, baikur, baikur, carolinandra, jacs127, julioreptil, davegabj, ALSKERT, zego2000, fer962933, 3fan, vvvv, DamaD, sodapas, subin91, yeka, ting tsai huang
 rusty
Hungary
User ID: 17227
Threads: 56
Likes: 1,880 in 283 posts
Given Likes: 539
09-04-2011, 04:58 AM
mirror links:
[-] The following 9 users Like rusty's post:9 users Like rusty's post
  β€’ vvvv, blaze, engrezi, Jackass, hmwere, yucapareja, user, lednar_ved, pedzaquino
  PCI Bridge Design Manual 3rd Ed. 2nd Rel. 2014 KMABD 0 3,313 01-13-2021, 12:28 PM
Last Post: KMABD
  Concrete Bridge Designer's Manual lamkin 8 7,737 06-15-2018, 08:17 PM
Last Post: axcel
  CIRIA C543 - Bridge Detailing Guide rami1976 0 2,063 11-04-2017, 08:15 PM
  TXDOT: Bridge Design Manual timosiβ„’ 2 3,405 08-22-2016, 09:51 AM
Last Post: ENGSAID
  Bridge Design Manual (LRFD- 2014 ) rami1976 0 2,102 12-17-2015, 07:25 PM
  ICE Manual of Bridge Engineering - by Gerard Parke, Nigel Hewson lamkin 9 8,018 02-13-2015, 06:51 AM
  AASHTO - Manual for Bridge Evaluation hich 1 3,005 09-14-2014, 12:22 PM
Last Post: Saze808
