Civil Engineering Association eBooks Journals, Papers and Presentations Evaluation of Egyptian code provisions for seismic design of moment-resisting-frame m
09-05-2014, 02:03 PM
Evaluation of Egyptian code provisions for seismic design of moment-resisting-frame multi-story buildings
Author: Shehata E Abdel Raheem | Size: 2.8 MB | Format: PDF | Quality: Unspecified | Publisher: International Journal of Advanced Structural Engineering 2013, 5:20 | Year: 2013 | pages: 18
Since the occurrence of the Cairo earthquake on October 1992, the design of structures for earthquakes became a
major demand enforced in the Egyptian design codes. The seismic response of building structures can be
estimated through utilization of a variety of analysis methods that range from simple equivalent static analysis to
complex nonlinear dynamic analysis. The traditional approach is to employ equivalent static analysis methods, while
current design practice is moving toward an increased emphasis on the nonlinear analysis method. The Egyptian
code provisions for building seismic design adopt the traditional approach of equivalent static load method as the
main method for evaluating seismic actions and recommend the response spectrum method for nonsymmetrical
buildings. This study aims to evaluate the Egyptian code provisions for the seismic design of moment-resistant
frame multi-story building through using nonlinear time history analysis. The analysis procedures are evaluated for
their ability to predict deformation demands in terms of inter-story drifts, potential failure mechanisms and story
shear force demands. The results of the analysis of the different approaches are used to evaluate the advantages,
limitations, and ease of application of each approach for seismic analysis.
  â€¢ cace-01, vardan, malc, ashcivilea, PinkPant, blaze, ykhackhack, bigone, civilgen
  Seismic Design of Steel Special Moment Frames: A Guide for Practicing Engineers yanburak 2 8,755 08-04-2021, 08:44 PM
Last Post: Wijono
  Seismic evaluation of a 56-storey residential reinforced concrete high-rise building anfaga 3 9,235 02-10-2016, 02:49 PM
  Propagating Waves in the Steel, Moment-Frame Factor Building Recorded during Earthqua TAFATNEB 0 4,939 07-03-2015, 09:57 PM
  Retrofitting steel special moment frame using ADAS metallic yielding dampers TAFATNEB 0 5,194 12-28-2014, 08:45 AM
  Non-Linear Seismic Response of Base-Isolated Frame Structures Using Rubber Bearings TAFATNEB 0 6,092 12-26-2014, 09:49 PM
  Seismic Demands on Steel Braced Frame Buildings with Buckling-Restrained Braces TAFATNEB 0 6,346 10-08-2014, 02:06 PM
  Seismic performance of concrete frame structures reinforced with superelastic shape TAFATNEB 0 6,288 09-05-2014, 01:59 PM
