Civil Engineering Association eBooks Journals, Papers and Presentations Influence of foundation stiffness on vibrations of rotor systems
08-11-2014, 10:54 AM
Author: P. Mažeika, J. Grigonienė, A. Senulis | Size: 381 MB | Format: PDF | Quality: Unspecified | Publisher: ISSN 1392-2114 ULTRAGARSAS (ULTR ASOUND), Vol.64, No.2, 2009. | Year: 2009 | pages: 5
[Image: 41968375811045527696.jpg]
In this paper mechanical system containing four horizontal blowers with separate frame each is analyzed. The system is fixed on one general foundation. The high level of vibrations is dominating during the work of the system. The results of experimental investigation of mechanical system are represented here. The finite element model of the operation investigated system gives possibility to investigate natural frequencies. The reasons of high level vibrations were identified by comparing the results of experimental data and theoretical calculations. The concept of vibrations reduction based on the results of this investigation was proposed as well.
  • vardan, malc, PinkPant, gulilero, zrilek, shadabg, febo927
  Dynamic Stiffness and Damping of a Shallow Foundation from Forced Vibration of a Fiel TAFATNEB 0 3,906 08-11-2014, 10:20 AM
  Analysis of machine foundation vibrations: state of the art TAFATNEB 0 4,426 08-11-2014, 10:00 AM
  Seismic evaluation of fluid-elevated tank-foundation/soil systems in frequency domain TAFATNEB 0 4,315 05-10-2014, 08:32 AM
  INFLUENCE OF THE STORY STIFFNESS OF REINFORCED CONCRETE FRAME WITH PROPORTIONAL HYSTE TAFATNEB 0 3,750 04-26-2014, 05:57 PM
  A general solution to vibrations of beams on variable winkler elastic foundation arshiakh 0 3,981 07-02-2013, 04:15 PM
Last Post: arshiakh
  Innovative foundation systems for high-rise buildings aslam 1 5,596 04-08-2013, 07:03 AM
  Dynamic stiffness of foundation on layered soil half-space using cone frustums mybest 0 4,891 09-19-2012, 02:51 PM
Last Post: mybest
