Civil Engineering Association eBooks Journals, Papers and Presentations FOOTFALL INDUCED VIBRATION IN LONGSPAN COMPOSITE STEEL BEAMS USED IN TWO PROJECTS AT
08-08-2014, 04:38 PM (This post was last modified: 08-08-2014, 08:21 PM by oanm2000.)
FOOTFALL INDUCED VIBRATION IN LONGSPAN COMPOSITE STEEL BEAMS USED IN TWO PROJECTS AT THE UNIVERSITY OF AUCKLAND
Author: V.N.Patel and R.J.Built | Size: 1.3 MB | Format: PDF | Quality: Unspecified | Publisher: Steel Innovations Conference 2013 Christchurch, New Zealand 21-22 February 2013 | Year: 2013 | pages: 13
Floor vibration due to human activity has become increasingly recognised by structural engineers, architects, and building owners as an inherent issue in long-span steel framed floor systems. In the past, attention was primarily focused on strength and deflection serviceability limits. However, as designers seek to push the limits on structural spans, grid spacings and adopt light-weight, low damping structural steelwork floor systems, more detailed consideration is required of the design tools and processes available to analyse and predict the vibration performance of floor systems.
Selection from published criteria of an “acceptable” vibration limit is sometimes possible depending upon the intended use of the space and the availability of manufacturers’ data for any vibration sensitive equipment. Building Owners and User Groups often have little understanding or quantitative “feel” for what performance the proposed “acceptable vibration limit” actually represents.
The theoretical predication of vibration performance against actual measured performance can sometimes vary significantly. This can lead to dispute post-construction as to whether the floor has an “acceptable” level of vibration. Post construction remediation of a space that is deemed to be “too lively” is often difficult, therefore, it is important that the vibration design criteria proposed are discussed and agreed and the limits of theoretical predications of vibration performance are clearly understood by all parties at the outset.
Beca Carter Hollings and Ferner Ltd (Beca) are currently in the process of designing two projects at the University of Auckland, utilising long-span partial-composite cellular steel beams. Both buildings will utilise existing structural frame layouts and foundations. As the new structure is to be built on the existing foundations, there is a necessity to keep it as lightweight as possible. The question of vibration sensitivity has been raised as a potential issue as both buildings contain research laboratories. An in-depth investigation has been conducted into the factors affecting vibration performance in order to give the Client and User Groups confidence that footfall induced vibration will not be an issue with the proposed floor structure.
[-] The following 2 users Like TAFATNEB's post:2 users Like TAFATNEB's post
  • r3be1, oanm2000
 r3be1
San Marino
User ID: 424
Threads: 49
Likes: 2,809 in 355 posts
Given Likes: 101
08-08-2014, 05:35 PM (This post was last modified: 08-08-2014, 05:36 PM by r3be1.)
the above link is not working for me; the one down there it does
[-] The following 7 users Like r3be1's post:7 users Like r3be1's post
  • blaze, gulilero, TAFATNEB, oanm2000, Dell_Brett, malc, slowet
  Measurement and modeling of footfall vibrations in a sensitive laboratory facility TAFATNEB 0 4,056 08-08-2014, 04:16 PM
  Simplified Methods for Estimating th e Response of Floors to a Footfall TAFATNEB 0 4,169 08-08-2014, 04:01 PM
  Evaluation of parameters affected on the blast induced ground vibration (BIGV) by usi TAFATNEB 0 4,186 08-31-2013, 10:09 PM
  Thermal buckling and postbuckling of laminated composite beams with temperature-depen asim99 0 3,782 05-11-2013, 06:03 PM
  Steel beams with large web openings of various shapes and sizes - by Chung,Liu,Ko andersen3 0 3,761 02-19-2013, 11:05 AM
