06-10-2014, 08:10 PM
(This post was last modified: 06-10-2014, 09:24 PM by Dell_Brett.)
Construction Calculations Manual
Author: Sidney M Levy | Size: 9.1 MB MB | Format: PDF | Quality: Unspecified | Publisher: Butterworth-Heinemann; | Year: (October 7, 2011) | pages: 700 | ISBN: 978-0123822437
![[Image: 22852837033703730594.jpg]](https://pic.civilea.com/images/22852837033703730594.jpg)
Written by one of the premier professionals in the field, Construction Calculations Manual provides end users with the calculations necessary for ensuring the on-time project delivery, within-budget projects. The proposed book will provide an owner, planning a construction project, with detailed calculations regarding site work, piping and pipe fitting, cost estimation, and overall project management.
The only book of its kind on the market today, this guide gives you all essential calculations used on the construction site. Day-to-day construction work calculations are presented in plain easy to read language. Time Saving calculations include:
- Complete Stair calculations for Risers, Treads, Stringer Length and Incline Angle
- Set Riser Height and solve for Stairwell Opening
- Built-in Right-Angle Functions for Square-ups, Slopes
- Area, Volume and Perimeter solutions with Length, Width and Height Keys
- Drywall, Siding and Paneling Key calculates
- Roof Function finds Area, Bundles, Squares and 4x8 Sheathing for Flat or Pitched Roofs
- Compound Miter - Store Crown Angle and Enter Wall Corner Angle to calculate the Blade Tilt and Angle for Miters cuts
- Board Feet Lumber estimating
- Work in and convert between building dimensions, including metric
- Built-in right-angle solutions
- Areas, volumes, square-ups
- Complete stair layouts
- Roof, rafter and framing solutions
- Circle: arcs, circumference, segments
π CLICK HERE π
Do not worry about your difficulties in Mathematics, I can assure you mine are still greater. Β -Albert EinsteinΒ Β Β Β Β Β
