Civil Engineering Association eBooks Journals, Papers and Presentations A NEW MODEL FOR JOINT SHEAR FAILURE OF REINFORCED CONCRETE INTERIOR BEAM-TO-COLUMN JO
06-01-2014, 03:35 PM
A NEW MODEL FOR JOINT SHEAR FAILURE OF REINFORCED CONCRETE INTERIOR BEAM-TO-COLUMN JOINT
Author: Hitoshi SHIOHARA | Size: 725 KB | Format: PDF | Quality: Unspecified | Publisher: Journal of the School of Engineering, The University of Tokyo, Vol. XLV (1998) | Year: 1998 | pages: 30
The primary objective of this study is to point out an irrationality in the joint shear failure model, which is adopted in the most current design codes of reinforced concrete beam-to-column joint. To examine this issue, tests of twenty reinforced concrete interior beam-to-columnjoint failed in joint shear are reexamined. The data indicated that joint shear stress had increased in the most specimens, even after apparent joint shear failure starts, while beam moment decreases due to decrease of flexural resistance which is caused by reduction of distance between stress resultants in beam at column face. The cause of the deterioration of story shear is identified to be a degrading of moment resistance of joint, originated from a finite upper limit of anchorage capacity of beam reinforcements through the joint core. So a new mathematical model for joint shear failure is introduced to reflect this fact. The behavior of the
model is investigated and a new approach for the design of beam-to-column joint in seismic zone is proposed based on the prediction of the model.
  â€¢ vardan, zrilek, blaze, cace-01, ting tsai huang, malc, nima_b12, Clouseau, Trishu999, sodapas
  Experiment and Analysis on X-Shaped Reinforced Concrete Joint in Diagrid Structures asim99 1 6,426 04-20-2018, 05:19 PM
Last Post: munycamsec
  Strength and Drift Capacity of GFRP- Reinforced Concrete Shear Walls TAFATNEB 0 5,094 03-16-2016, 09:41 AM
  Design Considerations for Shear Bolts in Punching Shear Retrofit of Reinforced Concre yakwetu 1 7,303 07-08-2015, 08:02 AM
Last Post: PinkPant
  Strut-and-Tie Model for Deep Beam Design odiclas 0 4,742 08-15-2014, 03:06 PM
Last Post: odiclas
  MECHANICAL NONLINEAR SHEAR WALL MODEL TAFATNEB 0 4,143 05-30-2014, 01:20 PM
  SEISMIC RETROFIT OF REINFORCED CONCRETE BRIDGES WITH FIBER REINFORCED POLYMER COMPOSI TAFATNEB 0 4,807 04-03-2014, 12:26 PM
  PEFORMANCE OF EXISTING REINFORCED CONCRETE COLUMNS UNDER BIDIRECTIONAL SHEAR AND AXIA TAFATNEB 0 4,157 08-27-2013, 08:45 AM
