Civil Engineering Association eBooks Structural Dynamics and Earthquake Engineering PERFORMANCE-BASED SEISMIC DESIGN OF EBF
 juice
User ID: 108
Threads: 7
Likes: 362 in 68 posts
Given Likes: 176
02-15-2009, 04:00 AM (This post was last modified: 12-29-2011, 06:16 PM by usman.)
USING TARGET DRIFT AND YIELD MECHANISM
AS PERFORMANCE CRITERIA
[Image: attachment.php?aid=129]
Eccentric braced steel frames (EBFs) are very efficient structures for resisting earthquakes as they combine the ductility of that is haracteristic of moment frames and the stiffness associated with braced frames. In the EBFs inelastic activity is confined to a small length of the floor beams which yields mostly in shear (therefore called the shear link). Capacity design approach is followed in an attempt to limit the inelastic activity to the shear links only while all other frame members are designed to behave elastically. Research work carried out during the seventies and eighties led to the formulation of design code provisions. However, current design practice generally follows elastic analysis procedures in proportioning the frame members. Therefore, it is possible that yielding in the shear links may not be uniformly distributed along the height of the structure and may be concentrated in a few floors causing excessive inelastic deformations at those levels, accompanied by significant plastic hinging in the columns.
download:
.jpg   Graphic1.jpg (Size: 59.74 KB / Downloads: 221)
[-] The following 14 users Like juice's post:14 users Like juice's post
  â€¢ Dell_Brett, Dell_Brett, yucapareja, yucapareja, orambo, orambo, aslam, aslam, oanm2000, oanm2000, bjliang, sivlad, andersen3, spat
 Elijah
User ID: 126
Threads: 16
Likes: 299 in 34 posts
Given Likes: 18
02-18-2009, 01:54 PM (This post was last modified: 06-24-2009, 06:29 PM by kamran.)
Dr. Shih-Ho Chao
Journal - Conferences - Technical - and more...
Chao, S.-H., and Goel, S. C. (2006), "Performance-Based Design of Eccentrically Braced Frames Using Target Drift and Yield Mechanism," AISC Engineering Journal, 3rd Quarter, 2006, pp. 173-200.
Chao, S.-H., Khandelwal, K., and El-Tawil, S. (2006), "Ductile Web Fracture Initiation in Steel Shear Links," ASCE Journal of Structural Engineering, Vol. 132, No. 8, August, 2006, pp. 1192-1200.
Parra-Montesinos, G. J., Peterfreund, S. W., and Chao, S.-H. (2005), "Highly Damage Tolerant Beam-Column Joints Through the Use of High-Performance Fiber Reinforced Cement Composites," ACI Structural Journal, V. 102, No.3, May-June, 2005, pp. 487-495.
[-] The following 12 users Like Elijah's post:12 users Like Elijah's post
  â€¢ bubieng, bubieng, Dell_Brett, Dell_Brett, cristi, cristi, amirdana, amirdana, oanm2000, oanm2000, sivlad, yeka
 Elijah
User ID: 126
Threads: 16
Given Likes: 18
06-23-2009, 01:13 PM (This post was last modified: 12-29-2011, 06:18 PM by usman.)
In the Dr. Shih-Ho Chao link,
search in Technical Report: Chao, S.-H., and Goel, S. C. (2005), "Performance-Based Seismic Design of Eccentrically Braced Frames Using Target Drift and Yield Mechanism as Performance Criteria," Report No. UMCEE 05-05, 149 pp.
Download
.pdf   EBF-Performance-Design.pdf (Size: 1.69 MB / Downloads: 216)
[-] The following 15 users Like Elijah's post:15 users Like Elijah's post
  â€¢ oanm2000, oanm2000, aslam, aslam, hrmarin, hrmarin, junaid, junaid, ruaumoko, sivlad, yeka, civilgr, andersen3, mgdario, TAFATNEB
  Energy-Based Seismic Engineering : Proceedings of IWEBSE 2021 TAFATNEB 0 3,191 06-28-2024, 02:44 PM
  Proceedings of the 4th International Conference on Performance Based Design in Earthq TAFATNEB 0 2,941 04-24-2023, 10:16 AM
  Displacement Based Seismic Design of Structures Grunf 13 12,512 02-21-2022, 06:37 PM
Last Post: ersin
  Performance-Based Seismic Design for Tall Buildings pezhmankhan 2 2,538 10-06-2021, 05:00 AM
  TBI: Guidelines for Performance-Based Seismic Design of Tall Buildings pezhmankhan 1 3,308 05-11-2019, 03:49 AM
  Seismic Isolation, Structural Health Monitoring, and Performance Based Seismic Desig carolinandra 0 2,100 01-16-2019, 03:14 PM
Last Post: carolinandra
  Performance-Based Seismic Design of Concrete Structures and Infrastructures amindoxiti 0 2,142 03-23-2018, 12:57 PM
