Civil Engineering Association eBooks General Books Civil Engineering MSc and PhD thesis Nonlinear Winkler-based shallow foundation model for performance assessment of seismi
05-09-2014, 06:00 PM (This post was last modified: 05-09-2014, 09:47 PM by oanm2000.)
Nonlinear Winkler-based shallow foundation model for performance assessment of seismically loaded structures
Author: Raychowdhury, Prishati | Size: 20.6 MB | Format: PDF | Quality: Original preprint | Publisher: UNIVERSITY OF CALIFORNIA, SAN DIEGO | Year: 2008 | pages: 326
[Image: 12563088792460508173.jpg]
Abstract:
When a structure supported on shallow foundations is subjected to inertial loading due to earthquake ground motion, the foundation may undergo sliding, settling and rocking movements. If the capacity of the foundation is mobilized, the soil-foundation interface will dissipate significant amounts of vibrational energy, resulting in a reduction in structural force demand. This energy dissipation and force demand reduction may enhance the overall performance of the structure, if potential consequences such as excessive tilting, settlement or bearing failure are accounted for.
Despite this potential benefit, building codes, particularly for new construction, discourage designs that allow foundation capacity mobilization. This lack of acceptance to embrace soil- foundation structure interaction (SFSI) as a design inelastic mechanism may stem from the well founded concern that significant uncertainties exist in characterization of soils. More importantly, the lack of well-calibrated modeling tools, coupled with parameter selection protocols cast in a simplistic fashion are lacking. In this work, a numerical model based on the Beam-on-Nonlinear-WinklerFoundation (BNWF) concept is developed to capture the above mentioned foundation behavior.
The BNWF model is selected due to its relative simplicity, ease of calibration, and acceptance in engineering practice. The soil-foundation interface is assumed to be an assembly of discrete, nonlinear elements composed of springs, dashpots and gap elements. Spring backbone curves typically used for modeling soil-pile response are taken as a baseline and further modified for their usefulness in shallow footing modeling. Evaluation of the model and associated parameter selection protocol is conducted using a suite of centrifuge experiments involving square and strip footings, bridge and building models, static and dynamic loading, sand and clay tests, a range of vertical factors of safety and aspect ratios. It is observed that the model can reasonably predict experimentally measured footing response in terms of moment, shear, settlement and
[-] The following 12 users Like TAFATNEB's post:12 users Like TAFATNEB's post
  â€¢ blaze, malc, vardan, ssobhan, rezart, oanm2000, ruaumoko, ting tsai huang, faros3000, ErnestoIII, PinkPant, hapsea
  Seismic Performance Assessment and Probabilistic Repair Cost Analysis of Precast Conc TAFATNEB 0 1,826 07-03-2015, 10:30 PM
  SEISMIC PERFORMANCE ASSESSMENT OF REINFORCED CONCRETE BUILDINGS WITH PRECAST CONCRETE TAFATNEB 0 2,129 03-27-2015, 03:16 PM
  Performance Based Approach in Seismic Design of Embedded Retaining Walls TAFATNEB 0 2,176 02-09-2015, 07:24 AM
  CONTINUUM DAMAGE MODEL FOR NONLINEAR ANALYSIS OF MASONRY STRUCTURES TAFATNEB 0 2,051 11-15-2014, 01:51 PM
  performance assessment of multistroyed rc special moment resisting frame TAFATNEB 0 1,853 06-03-2014, 07:30 AM
  Performance-Based Seismic Demand Assessment of Concentrically Braced Steel Frame Buil TAFATNEB 0 1,935 05-09-2014, 05:09 PM
  Seismic Performance, Modeling, and Failure Assessment of Reinforced Concrete Shear Wa TAFATNEB 0 1,900 05-09-2014, 04:00 PM
