Civil Engineering Association eBooks Journals, Papers and Presentations Reliability Analysis of Steel Building Frame Under Earthquake Forces
05-09-2014, 10:56 AM
Author: Dr. Rehan A. Khan , Prof. T. Naqvi | Size: 66 KB | Format: PDF | Quality: Unspecified | Publisher: International Journal of Emerging Technology and Advanced Engineering | Year: 2012 | pages: 6
[Image: 86797467144372859043.jpg]
Abstractβ€” A simplified fragility analysis of steel building
frame is presented which can be used for preliminary estimate
of its probability of failure. The risk analysis procedure uses
the format of probabilistic Risk Analysis (PRA) and considers
band limited white noise at the bed rock as the seismic input.
The steel building frame is modeled as a 2D frame and
Pushover analysis is then carried out to obtain its capacity
using SAP 2000. The response of the steel frame is obtained by
response spectrum method of analysis for multi-degree of
freedom system. The PRA includes uncertainties of the
response due to variation of ground motion, material
property, modeling & method of analysis and those of the
capacity due to the variation of ductility factor and damage
concentration effect. The proposed method of analysis is
applied to a 5-storey steel building frame for obtaining its
probability of failure using First Order Second Moment
(FOSM) theory of the Reliability analysis. The fragility curves
for the frame failure were generated for a number of
parametric variations. The parameters include soil conditions,
coefficient of variation of the uncertainty factors, ductility
factor and soil amplification factor . The study shows that all
the parameters considered in the study have considerable
effect on the probability of failure.
  β€’ vardan, sodapas, cace-01, zrilek, ting tsai huang, jcbv, blaze, malc, slowet
  Earthquake-Induced Collapse Simulation of a Super-Tall Mega-Braced Frame-Core Tube Bu TAFATNEB 1 8,708 10-30-2020, 08:45 AM
Last Post: gbn1980
  CTV Building Collapse - NLTHA Report - Christchurch Earthquake 2011 jamesmakeez 0 4,892 10-28-2016, 03:23 AM
Last Post: jamesmakeez
  Propagating Waves in the Steel, Moment-Frame Factor Building Recorded during Earthqua TAFATNEB 0 4,890 07-03-2015, 09:57 PM
  Retrofitting steel special moment frame using ADAS metallic yielding dampers TAFATNEB 0 5,148 12-28-2014, 08:45 AM
  NONLINEAR ANALYSIS FOR A REINFORCED CONCRETE FRAME STRUCTURE UNDER EXTREME LOADS TAFATNEB 0 6,242 11-15-2014, 02:07 PM
  Seismic Demands on Steel Braced Frame Buildings with Buckling-Restrained Braces TAFATNEB 0 6,304 10-08-2014, 02:06 PM
  Calculation of Earthquake Actions on Building Structures in Australia TAFATNEB 0 4,998 09-05-2014, 02:24 PM
