Civil Engineering Association eBooks General Books Civil Engineering MSc and PhD thesis NONLINEAR SEISMIC ANALYSIS OF QUASI-ISOLATION SYSTEMS FOR EARTHQUAKE PROTECTION OF BR
05-03-2014, 09:12 AM (This post was last modified: 05-03-2014, 09:14 AM by TAFATNEB.)
NONLINEAR SEISMIC ANALYSIS OF QUASI-ISOLATION SYSTEMS FOR EARTHQUAKE PROTECTION OF BRIDGES
Author: EVGUENI T. FILIPOV | Size: 7.8 MB | Format: PDF | Quality: Unspecified | Publisher: University of Illinois at Urbana-Champaign, 2012 | Year: 2012 | pages: 275
[Image: 62650406395053542940.jpg]
Quasi-isolation is a modern bridge seismic design philosophy where nonlinearity is permitted to occur in specific bearing components such that forces transferred into the
substructure are reduced and isolation is achieved by sliding of the bearings. The system is a pragmatic approach for providing earthquake resilient bridges in locations such as the eastern
and central United States, as well as in many locations around the world where there is significant earthquake risk at long recurrence periods. Such a seismic risk does not typically
justify the design of a rigorous classical isolation system, but instead, a low-complexity, low-cost quasi-isolation approach could provide significant mitigation of earthquake effects. The proposed system employs a set of fixed bearings at one intermediate substructure, and all other substructures are instrumented with isolation bearings that permit thermal expansion such as elastomeric bearings with an elastomer-concrete sliding interface or elastomeric bearings with a PTFE (Teflon) to stainless steel sliding interface. L-shaped steel side retainers are placed in the transverse direction of the elastomeric bearings, and along with the low-profile fixed bearings, these components prevent bridge movement during service oading, but break-off and permit sliding at high earthquake loads.
  â€¢ PinkPant, vardan, Mohammad6299, malc, blaze, rezart, zrilek
  Influence of Damping Systems On Building Structures Subject to Seismic Effects TAFATNEB 0 1,850 12-26-2014, 10:06 PM
  CONTINUUM DAMAGE MODEL FOR NONLINEAR ANALYSIS OF MASONRY STRUCTURES TAFATNEB 0 2,056 11-15-2014, 01:51 PM
  STEEL DISSIPATIVE BRACING SYSTEMS FOR SEISMIC RETROFITTING OF EXISTING STRUCT TAFATNEB 0 2,010 10-08-2014, 02:17 PM
  NONLINEAR ANALYSIS OF MULTISTORY STRUCTURES USING NONLIN TAFATNEB 0 2,158 10-06-2014, 10:12 AM
  Seismic Behaviour of Cable-Stayed Bridges: Design, Analysis and Seismic Devices TAFATNEB 0 2,028 08-31-2014, 07:45 AM
  SEISMIC RESPONSE OF UNANCHORED CYLINDRICAL LIQUID-TANK SYSTEMS TAFATNEB 0 1,892 05-10-2014, 09:35 AM
  Development of A Seismic Design Procedure for Metal Building Systems TAFATNEB 0 1,818 05-09-2014, 02:13 PM
