Civil Engineering Association eBooks Journals, Papers and Presentations Analytical Case Study of Seismic Performance of Retrofit Strategies for Reinforced Co
04-17-2014, 10:21 AM
Analytical Case Study of Seismic Performance of Retrofit Strategies for Reinforced Concrete Frames: Steel Bracing with Shear Links Versus Column Jacketing
Author: Mais M. Al-Dwaik and Nazzal S. Armouti | Size: 953 KB | Format: PDF | Quality: Unspecified | Publisher: Jordan Journal of Civil Engineering, Volume 7, No. 1, 2013 | Year: 2013 | pages: 18
[Image: 45447325361829825336.jpg]
The effectiveness of seismic retrofitting applied to enhance seismic performance is assessed for a five-storey reinforced concrete (RC) frame building structure as built in Jordan in mid 80s. The response of the structure is evaluated using nonlinear static and dynamic analysis with synthetic ground motion records for rock base.
FEMA 356 criteria are used to evaluate the seismic performance of the case study building. Two approaches are used for seismic evaluation: global-level evaluation (drift values) and member-level evaluation using three performance levels (immediate occupancy, life safety and collapse prevention). Based on the seismic evaluation results, two possible retrofit techniques are applied to improve the seismic performance of the structure, including the addition of RC column jackets and the addition of eccentric steel bracing. SAP 2000 is used to perform linear and nonlinear dynamic analysis, whereas plastic hinge analysis is performed by Response 2000. This study shows that adding new structural elements as steel members to an existing RC building proves to be effective in enhancing performance and reducing cost than adding RC elements. Even more, the eccentric bracing proves to outperform the column jacketing drift limit, plastic hinge limit and cost effectiveness.
  â€¢ ykhackhack, PinkPant, sodapas, rezart, vardan, malc, zrilek, ruaumoko, blaze, bigone, salahcivil
  Assessment of Shear Wall Building Seismic Performance by Nonlinear Analysis benny 2 12,740 08-01-2017, 09:19 AM
Last Post: abdulazizk
  Seismic Retrofitting of Historic Masonry Buildings – Case Study Grunf 3 10,814 05-26-2016, 03:19 AM
Last Post: gulilero
  Performance-based seismic assessment of skewed bridges bridgeengineer 0 5,411 04-22-2016, 06:31 AM
Last Post: bridgeengineer
  2nd ATC-SEI Conference on Improving the Seismic Performance of Existing Buildings and RyanRS 0 5,473 10-29-2015, 12:55 AM
Last Post: RyanRS
  Assessment of the seismic performance of a bituminous faced rockfill dam Wolverine883 0 6,184 07-19-2015, 07:24 AM
Last Post: Wolverine883
  Design Considerations for Shear Bolts in Punching Shear Retrofit of Reinforced Concre yakwetu 1 7,356 07-08-2015, 08:02 AM
Last Post: PinkPant
  Seminar Achieving Seismic Performance in Steel Connections RyanRS 2 8,275 09-22-2014, 09:21 PM
Last Post: inge911
