Civil Engineering Association Software Software Product Autodesk Products Autodesk Advanced Concrete 2015 x64
Threads: 1,118
04-16-2014, 07:40 AM (This post was last modified: 04-16-2014, 07:49 AM by BennyP.)
[Image: 59167463880027329579.gif]
[Image: 79880836452337316136.gif]
[Image: 43427311498607138770.gif]
Advance Concrete software for concrete design and detailing is built on the AutoCAD platform. Work with easy-to-use, comprehensive tools to help accelerate more accurate modeling and automate the creation of construction drawings and deliverables. Interoperability with Revit software supports a more connected Building Information Modeling (BIM) workflow.
Reinforcement modeling and detailing
Use a variety of tools to reinforce structural elements, including cast-in-place concrete, precast concrete, and special construction elements.
•Detail bars and meshes freely, directly on 2D drawings, as Advance Concrete creates and maintains a 3D model
•Select from a library of predefined bar shapes
•Assign parametric reinforcement attributes for each object (beams, columns, openings)
•Automate the placement of reinforcement bars and keep drawings up-to-date when models are modified
•Automatically optimize mesh and bent mesh reinforcements
•Create and visualize 3D reinforcement cages, and check clashes more easily
[-] The following 34 users Like BennyP's post:34 users Like BennyP's post
  • PinkPant, cace-01, dquan373, brandizzo, Mohammad6299, rezart, Dell_Brett, Gabemzaman, dl4all, ykhackhack, malc, Andrew seah, aema, dizz, seriousboy, stosto6666, oanm2000, TAFATNEB, vitacote, kln258, giga, jonny78, 3fan, faros3000, thanzawtun, cordoba123, hapsea, cristi, yutt, zrilek, Alex_Av, ali akbar, axcel, ebzr
Threads: 1,118
08-30-2014, 02:28 AM (This post was last modified: 08-30-2014, 02:29 AM by BennyP.)
All you need is to enter the Autodesk site, to search for "concrete"
Look at the screenshot - the file is 1.0 GB
[Image: 91119976283974823563.gif]
[-] The following 9 users Like BennyP's post:9 users Like BennyP's post
  • raja, learner20, emmi, araza023, Diquan, oanm2000, drewpt, engiman27, ali akbar
Threads: 1,118
01-07-2015, 05:36 PM
Autodesk Advance Concrete 2015.1
[Image: 49084909652318732109.gif]
[-] The following 13 users Like BennyP's post:13 users Like BennyP's post
  • Dell_Brett, mgdario, highcivil, zrilek, bridgeengineer, melekeen, PinkPant, rodleyzed, oanm2000, simanta, lissics, malc, dquan373
 gafi
User ID: 1273
Threads: 15
Likes: 323 in 29 posts
Given Likes: 326
01-09-2015, 01:17 PM
Product key for v2015.1 - 960G2.
[-] The following 2 users Like gafi's post:2 users Like gafi's post
  • bridgeengineer, lissics
Threads: 1,118
01-09-2015, 02:38 PM
Nice to see you translate what every one can see in the screenshot. For what you think I posted the screenshot, for giving you the opportunity to add a post ? Or you think I forgot ?
  Autodesk AutoCAD 2015 (x86/x64) BennyP 4 18,491 06-01-2017, 02:40 PM
Last Post: lesgiu
  Autodesk Revit Extensions 2015 KhaLed-S.E 0 4,866 03-28-2015, 08:53 AM
Last Post: KhaLed-S.E
  Autodesk AutoCAD 2015 Service Pack 2 rami1976 0 5,714 03-22-2015, 05:16 PM
  Autodesk AutoCAD Structural Detailing 2015 64bit BennyP 1 12,086 03-16-2015, 08:45 AM
Last Post: gianniorlati
  Autodesk AutoCAD Civil 3D 2015 x64 BennyP 2 8,420 03-10-2015, 09:32 PM
  Autodesk Revit 2015 X64 asim99 9 18,206 02-10-2015, 11:12 AM
  Autodesk Factory Design Suite Ultimate 2015.1 (x64) BennyP 0 4,148 01-02-2015, 10:00 AM
