Civil Engineering Association eBooks Journals, Papers and Presentations Pushover Analysis of 4 Storey’s Reinforced Concrete Building
04-09-2014, 06:14 PM
Author: Kavita Golghate :Vijay Baradiya: Amit Sharma | Size: 99 KB | Format: PDF | Quality: Unspecified | Publisher: International Journal of Latest Trends in Engineering and Technology (IJLTET) | Year: 2013 | pages: 5
The earthquakes in the Indian subcontinent have led to an increase in the seismic zoning factor over many
parts of the country. Also, ductility has become an issue for all building that was designed and detailed using earlier
versions of the codes. Under such circumstances, seismic qualification of building has become extremely important.
The structural engineering profession has been using the nonlinear static procedure (NSP) or pushover analysis.
Modeling for such analysis requires the determination of the nonlinear properties of each component in the structure,
quantified by strength and deformation capacities, which depend on the modeling assumptions. Pushover analysis is
carried out for either user-defined nonlinear hinge properties or default-hinge properties, available in some
programs based on the FEMA-356 and ATC-40 guidelines. This paper aims to evaluate the zone –IV selected
reinforced concrete building to conduct the non-linear static analysis (Pushover Analysis). The pushover analysis
shows the pushover curves, capacity spectrum, plastic hinges and performance level of the building. The non-linear
static analysis gives better understanding and more accurate seismic performance of buildings of the damage or
failure element.
[-] The following 12 users Like TAFATNEB's post:12 users Like TAFATNEB's post
  • rezart, malc, pedzaquino, gulilero, learner20, ting tsai huang, cace-01, vardan, blaze, melekeen, zrilek, anfaga
  Experiment and Analysis on X-Shaped Reinforced Concrete Joint in Diagrid Structures asim99 1 6,474 04-20-2018, 05:19 PM
Last Post: munycamsec
  Seismic evaluation of a 56-storey residential reinforced concrete high-rise building anfaga 3 9,235 02-10-2016, 02:49 PM
  POST-TENSIONED CONCRETE FLOORS IN MULTI-STOREY BUILDINGS ir_71 4 10,866 04-23-2015, 09:15 AM
Last Post: titko
  NONLINEAR ANALYSIS FOR A REINFORCED CONCRETE FRAME STRUCTURE UNDER EXTREME LOADS TAFATNEB 0 6,295 11-15-2014, 02:07 PM
  Pushover Analysis of I-5 RAVENNA Bridge TAFATNEB 0 5,165 08-14-2014, 08:26 AM
  Nonlinear Analysis of a Collapsed Reinforced Concrete Chimney TAFATNEB 0 4,409 08-10-2014, 02:59 PM
  Estimation of hysteretic energy demand using concepts of modal pushover analysis TAFATNEB 0 4,712 08-10-2014, 02:52 PM
