Civil Engineering Association Software Software Product Autodesk Products Using the 2014 XForce KG for 2015 versions
Threads: 1,118
03-19-2014, 09:42 AM
Once installed navigate to folder:
C:\Program Files\Common Files\Autodesk Shared\AdLM\
Rename folder R9 to R9old or something
Make a copy of folder R7 and rename it to R9
You should have:
R7 > original
R9 > copy of R7
R9old > renamed R9
(maybe you will need to re-do this for each Autodesk install)
I didn't, i activated all one after one.
Run your installed software - It will ask you to activate it.
Click on activate - It will take you to an activation screen.
Follow the instructions provided with the AUTODESK 2014 PRODUCTS UNIVERSAL KEYGEN.
[Image: 30304864692412136022.gif]
[Image: 51269146966424532368.gif]
[Image: 83604810826934993159.gif]
[Image: 16330773071381769558.gif]
[Image: 80273023902466241929.gif]
[Image: 25085015295710791406.gif]
[Image: 39470864989289046824.gif]
[-] The following 21 users Like BennyP's post:21 users Like BennyP's post
  • malc, pezhmankhan, ska51, rezart, Diquan, bigone, joker™, pingfan2, Mohammad6299, oanm2000, jcbv, kirankumarklk, petko666, cace-01, Dell_Brett, learner20, Quantumm, jonny78, milvio, amareen2000, KINIMOLEBA
  Autodesk 2015 pre release AutoCAD 2015 (64bit) BennyP 0 4,672 02-22-2014, 03:11 PM
  Trial versions of AutoCAD Products BennyP 1 5,044 03-29-2012, 05:56 AM
Last Post: warbeast
  xforce keygen 02410021 1 10,564 04-08-2010, 05:06 PM
Last Post: sia1
