Civil Engineering Association eBooks Journals, Papers and Presentations Uncertainties and dynamic problems of bolted joints and other fasteners
12-20-2013, 12:05 PM
Author: R.A. Ibrahima,*, C.L. Pettitb | Size: 1.6 MB | Format: PDF | Quality: Unspecified | Publisher: Journal of Sound and Vibration 279 (2005) 857–936 | Year: 2005 | pages: 80
[Image: 72833509979551282187.png]
This review article provides an overview of the problems pertaining to structural dynamics with bolted joints. These problems are complex in nature because every joint involves different sources of uncertainty and non-smooth non-linear characteristics. For example, the contact forces are not ideally plane due to manufacturing tolerances of contact surfaces. Furthermore, the initial forces will be redistributed nonuniformly in the presence of lateral loads. This is in addition to the prying loading, which is non-linear tension in the bolt and non-linear compression in the joint. Under environmental dynamic loading, the joint preload experiences some relaxation that results in time variation of the structure’s dynamic properties.
Most of the reported studies focused on the energy dissipation of bolted joints, linear and non-linear identification of the dynamic properties of the joints, parameter uncertainties and relaxation, and active control of the joint preload. Design issues of fully and partially restrained joints, sensitivity analysis to
variations of joint parameters, and fatigue prediction for metallic and composite joints will be discussed.
r 2003 Elsevier Ltd. All rights reserved.
  β€’ blaze, ting tsai huang, vardan, malc, ykhackhack
  Gust buffeting and turbulence uncertainties asim99 1 5,186 04-12-2017, 09:29 AM
Last Post: kristoffer_89
  Rainfall and sampling uncertainties: A rain gauge perspective asim99 0 4,260 03-27-2013, 06:12 AM
  Paper: Ductile Concentrically Braced Frames Using Slotted Bolted Joints struceng 0 4,604 10-24-2009, 09:41 AM
Last Post: struceng
