Civil Engineering Association eBooks Journals, Papers and Presentations Performance of Non - Linear E lastomeric Base - Isolated building structure
12-20-2013, 10:37 AM
Performance of Non-Linear Elastomeric Base-Isolated building structure
Author: Gomase O.P , Bakre S.V | Size: 506 KB | Format: PDF | Quality: Unspecified | Publisher: INTERNATIONAL JOURNAL OF CIVIL AND STRUCTURAL ENGINEERING Volume 2, No 1, 2011 | pages: 12 | ISBN: 0976 – 4399
[Image: 80633580867997600537.png]
The seismic response of multistory building supported on base isolation is investigated under real earthquake time history motion. The force deformation behavior of an isolator is modeled as Bi-linear hysteretic behavior which can be effectively used to model all isolation system in practice. Uniform Building Code (UBC-97) is widely used in design of base isolation systems which contains provision according for near fault effect. In order to investigate the performance of base isolation systems, design according to UBC-97 under near fault earthquake. Non-linear time history analysis of a four storey base isolated building, located at close to an active fault. The isolation system is composed of high damping rubber bearing. Design displacements are estimated using UBC-97 parameter. The building is subjected to 1979 El-Centro, 1995 Kobe and 1994 Northridge earthquakes. The analysis result shows that UBC-97 predicts isolator displacements successfully. Floor acceleration and inter-story drifts of the subject base isolated building are significantly reduced when compared to its fixed base counterpart.
  • malc, slowet, blaze, ting tsai huang, rezart, vardan, terrorruban
  Assessment of Shear Wall Building Seismic Performance by Nonlinear Analysis benny 2 12,740 08-01-2017, 09:19 AM
Last Post: abdulazizk
  Responses of isolated building with MR Dampers and Fuzzy Logic TAFATNEB 0 5,345 12-28-2014, 08:57 AM
  Non-Linear Seismic Response of Base-Isolated Frame Structures Using Rubber Bearings TAFATNEB 0 6,093 12-26-2014, 09:49 PM
  Evaluation Of Earthquake Response Analysis Methods For Low - Rise Base Isolated B. TAFATNEB 0 6,139 09-05-2014, 01:46 PM
  Pounding between base-isolated and fixed-base RC buildings during earthquakes TAFATNEB 0 4,317 08-14-2014, 07:52 AM
  RESPONSE ANALYSIS STUDY OF A BASE-ISOLATED BUILDING BASED ON SEISMIC CODES WORLDWIDE TAFATNEB 0 5,248 08-10-2014, 01:15 PM
  1 BUILDING PERFORMANCE IN THE BOUM ERDES, ALGERIA, EARTHQUAKE OF MAY 21, 2003 TAFATNEB 0 4,075 04-26-2014, 01:15 PM
