Civil Engineering Association eBooks Journals, Papers and Presentations Probabilistic evaluation of performance point in structures and investigation of the
Threads: 830
12-13-2013, 10:20 PM
Probabilistic evaluation of performance point in structures and investigation of the uncertainties
Author: F. Azhdary* and N. Shabakhty Department of Civil Engineering, University of Sistan and Baluchestan, Zahedan, Iran. | Size: 216 KB | Format: PDF | Quality: Unspecified | Publisher: Journal of Mechanical Engineering Research Vol. 3. (6), pp. 197-208, June 2011 | Year: 2011 | pages: 12
The main goal of the performance based design of structures is to rationally predict the structures’
performance during earthquakes which may occur during the lifetime of the structure. In this sort of
design, a specific displacement is defined as target displacement and the structure is subjected to a
force in order to reach this target displacement. This design process includes uncertainties in loading,
materials and analysis methods of the performance point. Therefore, statistical and probabilistic
analysis should be considered. In this paper, uncertainty sources for determining the performance
point are defined and then the procedures suggested in the codes are introduced. In the next step, an
appropriate probability distribution function is defined for uncertainty parameters and finally the
performance point of the structure is determined regarding these parameters in accordance with the
codes. In addition, the sensitivity of the performance point with respect to the mentioned parameters is
investigated. Results indicate that sensitivity of the performance point to geometric characteristics is of
great importance and other parameters such as dead and live load stand in the second level in terms of
sensitivity. An appropriate lateral loading pattern with the least uncertainty is also proposed for
buildings.
  â€˘ gulilero, malc, vardan, blaze
  Evaluation of the seismic performance of a three-story ordinary moment-resisting conc TAFATNEB 0 4,063 04-26-2014, 06:25 PM
  Investigation of progressive collapse in intermediate RC frame structures asim99 0 3,709 05-04-2013, 03:04 AM
  Performance Based Seismic Evaluation of Icon Hotel in Dubai-ATKINS kirankumarklk 0 5,031 09-28-2012, 01:20 PM
Last Post: kirankumarklk
  A performance-based adaptive methodology for the seismic evaluation of... cve_jule 0 3,758 07-15-2011, 10:18 AM
Last Post: cve_jule
  PERFORMANCE EVALUATION OF VARIOUS CORROSION PROTECTION SYSTEMS OF BRIDGES IN COLORADO ir_71 0 5,369 12-08-2010, 06:14 AM
