Civil Engineering Association eBooks Journals, Papers and Presentations CAPACITY SPECTRUM METHOD BASED ON INELASTIC DEMAND SPECTRA
12-13-2013, 10:10 PM
Author: PETER FAJFAR* Faculty of Civil and Geodetic Engineering, University of Ljubljana, Ljubljana, Slovenia | Size: 156 KB | Format: PDF | Quality: Unspecified | Publisher: EARTHQUAKE ENGINEERING AND STRUCTURAL DYNAMICS Earthquake Engng. Struct. Dyn. 28, 979}993 (1999) | Year: 1999 | pages: 15
By means of a graphical procedure, the capacity spectrum method compares the capacity of a structure with
the demands of earthquake ground motion on it. In the present version of the method, highly damped elastic
spectra have been used to determine seismic demand. A more straightforward approach for the determination
of seismic demand is based on the use of the inelastic strength and displacement spectra which can be
obtained directly by time-history analyses of inelastic SDOF systems, or indirectly from elastic spectra.
The advantages of the two approaches (i.e. the visual representation of the capacity spectrum method and
the superior physical basis of inelastic demand spectra) can be combined. In this paper, the idea of using
inelastic demand spectra within the capacity spectrum method has been elaborated and is presented in an
easy to use format. The approach represents the so-called N2 method formulated in the format of the
capacity spectrum method. By reversing the procedure, a direct displacement-based design can be performed.
The application of the modi"ed capacity spectrum method is illustrated by means of two examples.
Copyright
๐Ÿ‘‰ CLICK HERE ๐Ÿ‘ˆ
  โ€ข malc, blaze, vardan, ykhackhack, igor1234, draluka
  Ed Wilson - Termination of the Response Spectrum Method RyanRS 0 5,129 11-27-2015, 10:08 AM
Last Post: RyanRS
  Seismic Drift Demand and Capacity of Non-seismically Designed Concrete Buildings in H TAFATNEB 0 4,171 04-26-2014, 05:09 PM
  Performance-based plastic design method for buckling-restrained braced frames arshiakh 1 6,028 11-28-2013, 11:58 AM
  A simple image-based strain measurement method for measuring the strain ๏ฌelds in an R amritarao 0 4,008 02-22-2013, 04:39 PM
Last Post: amritarao
  IMPLEMENTATION OF THE DIRECT DISPLACEMENT-BASED DESIGN METHOD FOR SEISMIC DESIGN OF H Veggeta 3 8,337 09-22-2012, 03:40 PM
Last Post: ssobhan
  Inelastic Response Spectra for the Christchurch Earthquake Records miquan 0 5,113 10-08-2011, 02:09 PM
Last Post: miquan
  CAPACITY SPECTRUM METHOD Veggeta 1 7,034 01-16-2011, 06:14 AM
