Civil Engineering Association eBooks Journals, Papers and Presentations Nonlinear seismic assessment of lightly reinforced concrete intake towers
11-18-2013, 09:04 PM
Ensuring reservoir safety into the future. Thomas Telford, London, 2008 Nonlinear seismic assessment of lightly reinforced concrete intake towers
Author: R. SABATINO, Lloyd’s Register, London, UK (formerly KBR Ltd) A.J. CREWE, University of Bristol, UK W.E. DANIELL, University of Bristol, UK C.A. TAYLOR, University of Bristol, UK | Size: 1.8 MB | Format: PDF | Quality: Unspecified | Year: | pages: 14
[Image: 40269882173759137524.png]
Published guidance on the seismic analys is of reinforced concrete intake/outlet towers is limited, especiall
y for their nonlinear response, due to limited knowledge on the nonlinear characteristics ofexisting and new towers. Proving the integrity of existing towers is an international problem for dam owners, and an industrial need exists for arational, cost-effective and validated method for their assessment.This paper describes a series of tests aimed at investigating the seismic performance of typically reinforced, non-seismically designed towers.Monotonic and cyclic push-over tests were performed on 1/6th scaled models. The results from the physical tests were used to validate a 3D nonlinear finite element model of the towers, using embedded steel reinforcement and a smeared crack model to simulate crack properties of the concrete material. The dynamic performance of the structures was investigated by developing a simplified single degree of freedom model and performing a number of simulations to obtain fragility curves of the system. This simplified model was capable of simulating the degrading, hysteretic properties of the towers and was used to perform no nlinear time history analyses using a range of parameters. A probabilist ic approach was selected as the basis of the performance evaluation process using fragility analyses as a tool for modelling the uncertainty associated with the parameter selection. Based on the experimental and analytical results, a three-staged assessment procedure for the seismic performance assessment of the towers was proposed.
  â€¢ rezart, malc, vardan, blaze, zrilek
  Assessment of Shear Wall Building Seismic Performance by Nonlinear Analysis benny 2 12,647 08-01-2017, 09:19 AM
Last Post: abdulazizk
  Performance-based seismic assessment of skewed bridges bridgeengineer 0 5,365 04-22-2016, 06:31 AM
Last Post: bridgeengineer
  Seismic evaluation of a 56-storey residential reinforced concrete high-rise building anfaga 3 9,171 02-10-2016, 02:49 PM
  Assessment of the seismic performance of a bituminous faced rockfill dam Wolverine883 0 6,132 07-19-2015, 07:24 AM
Last Post: Wolverine883
  NONLINEAR ANALYSIS FOR A REINFORCED CONCRETE FRAME STRUCTURE UNDER EXTREME LOADS TAFATNEB 0 6,246 11-15-2014, 02:07 PM
  Seismic performance of concrete frame structures reinforced with superelastic shape TAFATNEB 0 6,245 09-05-2014, 01:59 PM
  SEISMIC VULNERABILITY ASSESSMENT USING AMBIENT VIBRATIONS: METHOD AND VALIDATION TAFATNEB 0 5,124 08-12-2014, 09:15 AM
