Civil Engineering Association Software Software Product Bentley Products Bentley GeoStructural Analysis v16.00.24.00 (incl. GeoStructural FEM)
 dl4all
User ID: 41680
Threads: 12
Likes: 210 in 26 posts
Given Likes: 137
10-20-2013, 02:20 PM (This post was last modified: 10-22-2013, 03:34 AM by Dell_Brett.)
[Image: 84557180710128605747.jpeg]
Bentley GeoStructural Analysis is geotechnical analysis software, which allows you to evaluate alternate design scenarios within a single, interoperable product suite, ensuring that the subsurface data is used efficiently for an integrated project delivery.
Bentley GeoStructural Analysis includes Excavation Analysis, Foundation Analysis, and Retaining Wall Analysis.
GeoStructural Finite Element Analysis
The GeoStructural Finite Element Analysis suite contains tools for performing Finite Element modeling for a range of geotechnical problems including excavation, slope stability, foundation beams, settlement, tunneling, and more.
Key Features
Leverage a database of material models to accurately represent soil or rock mass properties
Model ground water conditions by defining the ground water table (GWT) or the pore water pressure distribution
Construct problems in axisymmetric or plane strain space
Utilize time-saving input of project information using DXF file format and automatic mesh generator
Generate boundary conditions automatically or through individual specification
Specify analysis for stress distribution, stability, fluid flow, and tunnels
Specify regional design standards for concrete (e.g., ACI) and steel structures
Accurately model complex multi-stage construction projects
Analyze an unlimited number of anchor, geogrid, and geotextile elements
Analyze an unlimited number of surcharge loads
Analyze project for stability throughout construction sequence to identify
[-] The following 15 users Like dl4all's post:15 users Like dl4all's post
  â€¢ Williams, oanm2000, zrilek, subin91, aema, 3fan, BuSeongKim, Rainbow, shadabg, englandboy, malc, olgabehe, axcel, TAFATNEB, jacky899
10-21-2013, 08:27 AM (This post was last modified: 10-21-2013, 08:40 AM by Dell_Brett.)
Bentley GeoStructural Analysis 16.00
[Image: 75099266623428450187.jpeg]
Geotechnical analysis software allows you to evaluate alternate design scenarios within a single, interoperable product suite, ensuring that the subsurface data is used efficiently for an integrated project delivery.
Bentley provides the following geotechnical design & analysis offerings. Which product is right for you?
About Bentley Systems, Incorporated
Bentley is the global leader dedicated to providing architects, engineers, geospatial professionals, constructors, and owner-operators with comprehensive software solutions for sustaining infrastructure. Bentley Systems applies information mobility to improve asset performance by leveraging information modeling through integrated projects for intelligent infrastructure. Its solutions encompass the MicroStation platform for infrastructure design and modeling, the ProjectWise platform for infrastructure project team collaboration and work sharing, and the AssetWise platform for infrastructure asset operations - all supporting a broad portfolio of interoperable applications and complemented by worldwide professional services. Founded in 1984, Bentley has more than 3,000 colleagues in 50 countries, more than $500 million in annual revenues, and since 2003 has invested more than $1 billion in research, development, and acquisitions.
Name: Bentley GeoStructural Analysis
Version: 16.00.00.00
Home:
Interface: english
OS: Windows XP / Vista / Seven
[-] The following 3 users Like TAFATNEB's post:3 users Like TAFATNEB's post
  â€¢ 3fan, blaze, oanm2000
10-21-2013, 07:41 PM
Bentley GeoStructural Analysis 16.00.24
[Image: 25107673922902309784.jpeg]
GeoStructural Analysis (GSA) suite of programs is designed to solve various geotechnical problems. Each program is used to analyze a different geotechnical task but all programs communicate with each other to form an integrated suite.
The suite integrates programs from GeoStructural Foundation Analysis, Geostructural Retaining Wall Analysis and GeoStructural Excavation Analysis into one convienient product suite.
Some of the GeoStructural Analysis programs provide gINT import of soil properties required for geotechnical analysis.
Bonus: Bentley GeoStructural FEM 16.00.24.00
The program can model a wide range of geotechnical problems including terrain settlement, sheet piling/diaphragm walls, underpinning of structures, slope stability, beams on foundation, excavation, etc.
[-] The following 15 users Like TAFATNEB's post:15 users Like TAFATNEB's post
  â€¢ oanm2000, 3fan, malc, Dell_Brett, viet2010, BuSeongKim, zrilek, Rami11, huy2009, chenamoy, PinkPant, blaze, Andrew seah, serhioSPA, jacky899
 rigid_joint
Senior Member
Jamaica
User ID: 6110
Threads: 13
Likes: 333 in 122 posts
Given Likes: 244
12-29-2013, 10:48 AM
Dear all, the above links as far as I've checked, don't contain the GeoStructural Finite Element Analysis module.
I have uploaded the FEM module trial version here
[-] The following 4 users Like rigid_joint's post:4 users Like rigid_joint's post
  â€¢ malc, Andrew seah, Dell_Brett, bigone
  Bentley GeoStructural Analysis v19.00.41.00 & Bentley GeoStructural Finite Element rami1976 1 11,149 10-15-2018, 07:57 AM
  Bentley GeoStructural Finite Element Analysis v17.00.33.00 jacky899 1 7,839 04-18-2014, 05:12 AM
Last Post: al_frd
  Bentley GeoStructural Analysis 16.0 (trial) BennyP 2 8,734 08-08-2013, 11:52 AM
Last Post: 3fan
  Bentley GeoStructural Analysis (Fine Geo V13.7) Demo asumi 6 16,492 06-06-2013, 09:07 PM
Last Post: bubieng
