Civil Engineering Association eBooks Journals, Papers and Presentations Scientific journals and Research papers Shake table tests of under-designed RC frames for the seismic retrofit of buildings –
Threads: 830
09-10-2013, 02:14 PM
Shake table tests of under-designed RC frames for the seismic retrofit of buildings – design and similitude requirements of the benchmark specimen
Author: P. Quintana-Gallo, S. Pampanin, & A.J. Carr ; P. Bonelli | Size: 2.8 MB | Format: PDF | Quality: Unspecified | Publisher: 2010 NZSEE Conference | Year: 2010 | pages: 12
[Image: 74794780846943696595.png]
In the past years, extensive experimental work on innovative feasible retrofit solutions has been carried out at the University of Canterbury, as part of the FRST Project ‘Seismic Retrofit Solutions for NZ Multi-storey Buildings’. The experiments have consisted in quasi-static test of 2/3 scale beam column joint subassemblies representative of pre-70’s reinforced concrete (RC) frame buildings, referred herein as under-designed structures (non-ductile detailing, no capacity design principles), before and after retrofit.
As a dynamic validation of the seismic vulnerability of such structures and the feasibility of the developed and improved retrofit solutions, a series of 4 1/2.5 scale experimental models (two 3 storey - 2 bay frames jointed together by transverse beams and floor slabs) will be tested on the shake table, without and with a seismic retrofit intervention and without and with infill panels. The retrofit interventions will include techniques such as the Metallic Haunch, FRP layers, and Shape Memory Alloys (SMA) braces, targeting for two different performance levels: Life Safety and Damage Control. In this paper, the overall description of the dynamic tests, the development of the experimental models and the similitude requirements are described.
  • blaze, vardan, malc, faros3000, sodapas
  Effect of floor slabs on the seismic performance of RC frames TAFATNEB 3 8,665 07-17-2014, 08:07 AM
  Seismic Retrofit of Elevated Steel Water Tanks TAFATNEB 0 3,573 05-10-2014, 08:23 AM
  Full-scale Tests for Seismic Performance Verification of Steel Building Structures wi TAFATNEB 0 4,195 08-31-2013, 12:21 PM
  Seismic Retrofit of RC Frame Buildings with Masonry Infill Walls datagap 0 5,428 12-19-2010, 12:49 AM
Last Post: datagap
  Seismic behaviour of eccentrically braced frames preceptor 1 5,560 04-26-2010, 01:56 PM
Last Post: Grunf
  Dynamic Behaviour of Reinforced Concrete Frames Designed with Direct Displacemen-Base Veggeta 2 6,771 03-08-2010, 08:55 AM
Last Post: Grunf
