Civil Engineering Association eBooks Structural Dynamics and Earthquake Engineering REDUNDANCY IN STEEL MOMENT FRAME SYSTEMS UNDER SEISMIC EXCITATIONS
09-10-2013, 02:00 PM
Author: Kuo-Wei Liao Yi-Kwei Wen | Size: 7.2 MB | Format: PDF | Quality: Unspecified | Publisher: DEPARTMENT OF CIVIL AND ENVIRONMENTAL ENGINEERING UNIVERSITY OF ILLINOIS AT URBANA-CHAMPAIGN URBANA, ILLINOIS | Year: 2004 | pages: 172
[Image: 19563685226809332830.png]
Although the importance and the positive effects of structural redundancy have
been long recognized, structural redundancy became the focus of research only after the
1994 Northridge and 1995 Kobe earthquakes. Several researchers have investigated the
benefit of redundancy to structural system. However, the definition and interpretation of
structural redundancy vary significantly and it remains a controversial subject.
A reliability/redundancy factor, p, was introduced in NEHRP 97, UBC 1997, and
IBC 2000. It is used as a multiplier of the lateral design earthquake load and takes into
account only the floor area and maximum element-story shear ratio. It lacks an adequate
rationale and can lead to poor structural designs (e.g. Searer G. R. and Freeman S. A.,
2002, Wen and Song, 2003). A new reliability/redundancy factor, primary a function of
plan configuration of the structures such as the number of moment frames in the direction
of earthquake excitations, has been adopted in NEHRP 2003 and also proposed in ASCE-
7. This new factor attempts a more reasonable and mechanism-based approach, and it likely to be implemented in other codes in the near future. However, the uniform
multiplied factor (1.3) of lateral design force for non-redundancy structures fails to
account for different structural configurations and could lead to serious damage in poorly designed structure. In view of the complicated nonlinear structural behaviors and
the effects of uncertainty in demand and capacity, redundancies of structures under
seismic loads can be measured meaningfully only in terms of reliability of a given system.
Therefore, a systematic and probabilistic study of redundancy in structural system is
needed and a uniform-risk redundancy factor is used for reliability assessment of
structural redundancy.
  â€¢ blaze, jcbv, malc, sodapas, Dell_Brett, bigone, Sumatra, mgdario
  Smart Structures Innovative Systems for Seismic Response Control TAFATNEB 0 3,206 06-28-2024, 08:15 AM
  Seismic Behavior and Design Guidelines for Steel Frame Structures with Added Viscoela david-smith 3 4,148 12-20-2022, 07:30 PM
Last Post: bridgeengineer
  Textbook of Seismic Design - Structures, Piping Systems, and Components subin91 1 2,369 09-17-2019, 10:16 AM
  Smart Connection Systems: Design and Seismic Analysis subin91 3 3,201 03-01-2017, 05:47 PM
Last Post: Veggeta
  Handbook of Seismic Risk Analysis and Management of Civil Infrastructure Systems. asim99 5 3,776 01-19-2015, 06:05 PM
Last Post: Veggeta
  Smart Structures: Innovative Systems for Seismic Response Control oanm2000 6 4,918 11-28-2014, 08:06 AM
  Integrated Seismic Design of Structure and Control Systems pezhmankhan 1 2,114 08-26-2014, 06:10 PM
Last Post: r3be1
