Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Books and Codes Request [REQUEST] Handbook on Design And Construction of Drilled Shafts Under Lateral Load
[Request] Handbook on Design And Construction of Drilled Shafts Under Lateral Load
 tomcat007
User ID: 13907
Threads: 21
Likes: 12 in 5 posts
Given Likes: 59
08-29-2013, 05:19 AM
Hi All,
Does someone have the following book?
"Handbook on Design And Construction of Drilled Shafts Under Lateral Load" from FHWA
Please share if you have it.
Thanks and Regards,
[-] The following 1 user Likes tomcat007's post:1 user Likes tomcat007's post
  β€’ freequo
 f_slikken
User ID: 21091
Threads: 9
Likes: 910 in 88 posts
Given Likes: 778
12-31-2014, 02:00 AM
All,
Just to keep this post active.
I do appreciate if any one can share this handbook.
  β€’
 mahyarov
User ID: 1197
Threads: 452
Likes: 3,226 in 534 posts
Given Likes: 1492
01-24-2015, 02:51 PM (This post was last modified: 01-24-2015, 03:32 PM by Dell_Brett.)
  β€’ zrilek, blaze, bridgeengineer, f_slikken
 ALMF
User ID: 1069
Threads: 4
Likes: 493 in 61 posts
Given Likes: 39
01-24-2015, 04:56 PM
The Technical Manual FHWA-IF-99-025 has errors. Right here the erratum.
ALMF
[-] The following 2 users Like ALMF's post:2 users Like ALMF's post
  β€’ zrilek, f_slikken
 gulilero
Italy
User ID: 14057
Threads: 102
Likes: 4,989 in 647 posts
Given Likes: 6732
01-24-2015, 07:47 PM
The links posted above do no correspond to the requested reference.
Drilled Shafts Handbook on Design And Construction of Drilled Shafts Under Lateral Load, 1984 FHWA-IP-84-11 PB85-201085
The links provided are for:
Drilled Shafts; Construction Procedures and Design Methods, 1999 FHWA-IF-99-025 PB85-201085
Which has been superseded by:
Drilled Shafts: Construction Procedures
and LRFD Design Methods
Publication No. FHWA-NHI-10-016
FHWA GEC 010
May 2010
U.S. Department of Transportation
Federal Highway Administration
NHI Course No. 132014
Developed following:
AASHTO LRFD Bridge Design Specifications,
4th Edition, 2007, with 2008 and 2009 Interims.
as it reads:
This document is a major update and revision of the 1999 FHWA Drilled Shafts manual authored by
Michael W. O’Neill and Lymon C. Reese, Publication No. FHWA-IF-99-025.
[-] The following 8 users Like gulilero's post:8 users Like gulilero's post
  β€’ Dell_Brett, bridgeengineer, zrilek, isurya, f_slikken, PinkPant, Mohammad6299, blaze
  [REQUEST] Design Guide for Drilled Piers civilfafa 0 1,595 08-28-2021, 11:45 PM
Last Post: civilfafa
  [REQUEST] CSA S16-14 Handbook for Steel Construction cristanx 1 1,654 01-22-2019, 06:21 AM
  [REQUEST] Steel Structures Design for Lateral and Vertical Forces pezhmankhan 1 2,329 05-05-2018, 08:51 AM
Last Post: sabooryan
