Civil Engineering Association eBooks Journals, Papers and Presentations Development and evaluation of improved details for ductile welded unreinforced flange
 arshiakh
User ID: 37777
Threads: 97
Likes: 3,224 in 617 posts
Given Likes: 214
08-13-2013, 09:54 AM
Development and evaluation of improved details for ductile welded unreinforced flange connections
Author: Ricles, James M | Size: 19.7 MB | Format: PDF | Quality: Unspecified | Publisher: NISEE e-Library | Year: 2000 | pages: 439 | ISBN: ----
[Image: 68700285187126802655.jpg]
Reports on results of a combined analytical and experimental investigation to improve the cyclic inelastic performance of welded steel, unreinforced flange moment connections for use in earthquake resistant construction. Issues such as the geometry and size of the weld access holes, the amount of inelastic panel zone deformation, the use of supplemental web fillet welds, the influence of continuity plates, and the effects of a concrete slabs are all studied as part of the investigation.
[-] The following 9 users Like arshiakh's post:9 users Like arshiakh's post
  â€¢ malc, oanm2000, jcbv, ssobhan, fred2010, Dell_Brett, kowheng, slowet, RyanRS
  A Pseudo-Dynamic Method to Analyze Retaining Wall with Reinforced and Unreinforced Ba TAFATNEB 0 3,803 04-27-2014, 08:29 AM
  IDENTIFYING CONFIGURATION AND CONNECTION DETAILS OF UNREINFORCED MASONRY STRUCTURES I TAFATNEB 0 3,694 11-02-2013, 11:16 AM
  Optimum design of steel frames using a multiple-deme GA with improved reproduction op arshiakh 0 3,600 04-26-2013, 07:57 PM
Last Post: arshiakh
  SIMULATION-BASED FRAGILITY RELATIONSHIPS FOR UNREINFORCED MASONRY BUILDINGS JUANCM 0 5,085 10-04-2010, 06:52 PM
Last Post: JUANCM
