Civil Engineering Association eBooks General Books Performance Based Building Design 1: From Below Grade Construction to Cavity Walls
 asim99
User ID: 9774
Threads: 461
Likes: 6,384 in 594 posts
Given Likes: 377
08-03-2013, 11:26 PM
Author: Hugo Hens( | Size: 12 MB | Format: PDF | Quality: Unspecified | Publisher: Wiley-Blackwell | Year: 2012 | pages: 270 | ISBN: 9783433030226
[Image: 73914239997845604406.jpg]
Just like building physics, performance based building design was hardly an issue before the energy crises of the 1970s. With the need to upgrade energy efficiency, the interest in overall building performance grew. As the first of two volumes, this book applies the performance rationale, advanced in applied building physics, to the design and construction of buildings. After an overview of materials for thermal insulation, water proofing, air tightening and vapour tightening and a discussion on joints, building construction is analysed, starting with the excavations. Then foundations, below and on grade constructions, typical load bearing systems and floors pass the review to end with massive outer walls insulated at the inside and the outside and cavity walls. Most chapters build on a same scheme: overview, overall performance evaluation, design and construction.
This third book, after Building Physics and Applied Building Physics, is the result of 38 years of teaching architectural, building and civil engineers, coupled to more than 40 years of experience in research and consultancy. Where and when needed, input and literature from over the world was used, reason why each chapter ends listing references and literature.
The book should be usable by undergraduates and graduates in architectural and building engineering, though also building engineers, who want to refresh their knowledge, may benefit. The level of discussion assumes the reader has a sound knowledge of building physics, along with a background in structural engineering, building materials and building construction.
Content:
Chapter 0 Introduction (pages 1–5):
Chapter 1 Performances (pages 7–12):
Chapter 2 Materials (pages 13–53):
Chapter 3 Excavations and Building Pit (pages 55–56):
Chapter 4 Foundations (pages 57–68):
Chapter 5 Building Parts on and below Grade (pages 69–110):
Chapter 6 Structural Options (pages 111–121):
Chapter 7 Floors (pages 123–148):
Chapter 8 Outer Wall Requirements (pages 149–155):
Chapter 9 Massive Outer Walls (pages 157–214):
Chapter 10 Cavity Walls (pages 215–253):
Chapter 11 Panelized Massive Outer Walls (pages 255–262):
[-] The following 14 users Like asim99's post:14 users Like asim99's post
  • malc, Jackass, ibg0203, vardan, mahyarov, fred2010, Petrit, avscorreia, blaze, Dell_Brett, gulilero, kowheng, ssobhan, ykhackhack
 ssobhan
User ID: 1054
Threads: 224
Likes: 8,975 in 1,182 posts
Given Likes: 2465
08-10-2013, 12:52 AM
[/MIRROR] 🔽🔽🔽🔽🔽🔽🔽🔽🔽
[-] The following 2 users Like ssobhan's post:2 users Like ssobhan's post
  • Dell_Brett, slowet
  Performance-Based Fire Safety Design cace-01 1 2,202 08-15-2018, 04:31 PM
Last Post: febo927
  Handbook of Green Building Design and Construction-2nd Edition febo927 0 1,826 07-24-2018, 12:46 PM
Last Post: febo927
  Bio-aggregates Based Building Materials ibg0203 1 2,076 03-13-2017, 09:06 AM
  Sustainable Construction: Green Building Design and Delivery toa011 5 4,359 05-31-2016, 06:05 PM
Last Post: ibg0203
  Assessing Building Performance lisine 1 2,530 01-27-2016, 04:33 AM
  Green Building with Concrete: Sustainable Design and Construction portal61 5 4,022 11-23-2015, 03:42 PM
Last Post: ibg0203
  Performance Based Building Design 2: From Timber-Framed Construction to Partition Wal asim99 2 2,708 10-21-2015, 02:45 PM
Last Post: ibg0203
