Civil Engineering Association eBooks Journals, Papers and Presentations Interactive Mechanical Model for Shear Strength of Deep Beams (With Discussion & Clos
 asim99
User ID: 9774
Threads: 461
Likes: 6,384 in 594 posts
Given Likes: 377
05-27-2013, 08:48 PM
Interactive Mechanical Model for Shear Strength of Deep Beams (With Discussion & Closure)
Author: Tang, C. and Tan, K. | Size: 298 KB | Format: PDF | Quality: Unspecified | Publisher: ASCE | Year: 2004 | pages: 15
The current American Concrete Institute code states that the nominal shear strength Vn of a reinforced concrete deep beam
consists of the concrete contribution Vc and shear reinforcement contribution Vs, i.e., Vn=Vc+Vs. In this paper, however, a very different
yet original approach is presented. The method is based on strut-and-tie approach, with the effect of transverse tensile stresses on concrete
compressive strength of the diagonal strut properly accounted for. Two common failure modes, namely, diagonal splitting and concrete
crushing, are examined in the paper. Premature failures such as shear tension failure (due to insufficient anchorage of main longitudinal
reinforcement) and bearing failures are not considered. The resistance to diagonal splitting is mainly provided by the main and shear
reinforcement. Additional resistance from concrete tensile strength is included in the analysis. The resistance to crushing of concrete is
contributed by the concrete compressive strength. Ultimate shear strengths of deep beams are governed by both the transverse tensile
stresses perpendicular to the diagonal strut, and the compressive stresses in the diagonal strut, resulting in an interaction between the two
failure modes. Predictions by the proposed modal are compared with experimental results and other established calculation methods.
Generally, the predictions are not only accurate and consistent in each case study, but also conservative.
[-] The following 11 users Like asim99's post:11 users Like asim99's post
  â€¢ vardan, Jackass, Dell_Brett, viet2010, kowheng, Mohammad6299, malc, Albert, vvvv, blaze, sodapas
  Strength and Drift Capacity of GFRP- Reinforced Concrete Shear Walls TAFATNEB 0 5,144 03-16-2016, 09:41 AM
  Strut-and-Tie Model for Deep Beam Design odiclas 0 4,795 08-15-2014, 03:06 PM
Last Post: odiclas
  A NEW MODEL FOR JOINT SHEAR FAILURE OF REINFORCED CONCRETE INTERIOR BEAM-TO-COLUMN JO TAFATNEB 0 4,125 06-01-2014, 03:35 PM
  MECHANICAL NONLINEAR SHEAR WALL MODEL TAFATNEB 0 4,175 05-30-2014, 01:20 PM
  Empirical Correlations: Drained Shear Strength for Slope Stability Analyses asim99 0 4,059 06-15-2013, 04:46 PM
  Size Effect on Shear Strength of Deep Beams: Investigating with Strut-and-Tie Model asim99 0 4,507 05-27-2013, 08:44 PM
  Single-Span Deep Beams Subjected to Unsymmetrical Loads asim99 0 3,679 05-27-2013, 08:40 PM
