Civil Engineering Association eBooks Codes, Manual & Handbook ISO ISO 13788:2012 - Hygrothermal performance of building components and building element
 asim99
User ID: 9774
Threads: 461
Likes: 6,384 in 594 posts
Given Likes: 377
05-16-2013, 02:59 AM
ISO 13788:2012 - Hygrothermal performance of building components and building elements - Internal surface temperature to avoid critical surface humidity and interstitial condensation - Calculation methods
Author: CEN members | Size: 880 KB | Format: PDF | Quality: Unspecified | Publisher: EUROPEAN COMMITTEE FOR STANDARDIZATION | Year: 2012 | pages: 50
[Image: 75382906271762319875.jpg]
ISO 13788:2012 gives simplified calculation methods for:
1. The internal surface temperature of a building component or building element below which mould growth is likely, given the internal temperature and relative humidity. The method can also be used to assess the risk of other internal surface condensation problems.
2. The assessment of the risk of interstitial condensation due to water vapour diffusion. The method used does not take account of a number of important physical phenomena including the variation of material properties with moisture content; capillary suction and liquid moisture transfer within materials; air movement from within the building into the component through gaps or within air spaces; the hygroscopic moisture capacity of materials.
3. The time taken for water, from any source, in a layer between two high vapour resistance layers to dry out and the risk of interstitial condensation occurring elsewhere in the component during the drying process.
[-] The following 9 users Like asim99's post:9 users Like asim99's post
  â€¢ Dell_Brett, ir_71, andersen3, st77bel, blaze, Jackass, kowheng, peixoto, vvvv
Threads: 49
01-08-2015, 05:27 PM
new link
[/MIRROR] 🔽🔽🔽🔽🔽🔽🔽🔽🔽
password:
  â€¢ PinkPant, bridgeengineer, Dell_Brett, malc, babios
 lisine
Vanuatu
User ID: 17927
Threads: 265
Likes: 11,713 in 1,307 posts
Given Likes: 4631
11-29-2017, 11:23 AM
[-] The following 9 users Like lisine's post:9 users Like lisine's post
  â€¢ amindoxiti, vvvv, cace-01, zrilek, Songoku, PinkPant, Dell_Brett, Trishu999, oanm2000
