Civil Engineering Association eBooks Journals, Papers and Presentations Progressive collapse resisting capacity of moment frames with viscous dampers
 asim99
User ID: 9774
Threads: 461
Likes: 6,384 in 594 posts
Given Likes: 377
05-04-2013, 02:51 AM
Author: Jinkoo Kim, Seungjun Lee and Hyunhoon Choi | Size: 1.35 MB | Format: PDF | Quality: Unspecified | Publisher: Wiley | Year: 2011 | pages: 16
In this paper, the effect of viscous dampers on reducing progressive collapse potential of steel moment
frames was evaluated by nonlinear dynamic analysis. Parametric studies were conducted fi rst to evaluate
the effects of dampers installed in a steel beam-column subassembly with varying natural period and yield
strength on the reduction of progressive collapse potential. Then 15-story moment-resisting frames with
three different span lengths were designed with and without viscous dampers, and the effect of viscous
dampers was investigated by nonlinear dynamic analysis. According to the parametric study, the vertical
displacement generally decreased as the damping ratio of the system increased, and the dampers were
effective in both the elastic and the elasto-plastic systems. It was also observed that the effect of the damper
increased as the natural period of the structure increased and the strength ratio decreased. The analysis
results of 15-story analysis model structures showed that the viscous dampers, originally designed to reduce
earthquake-induced vibration, were effective in reducing vertical displacement of the structures caused by
sudden removal of a fi rst-story column, and the effect was more predominant in the structure with longer
span length.
[-] The following 2 users Like asim99's post:2 users Like asim99's post
  β€’ jcbv, malc
  Seismic Design of Steel Special Moment Frames: A Guide for Practicing Engineers yanburak 2 8,663 08-04-2021, 08:44 PM
Last Post: Wijono
  Progressive collapse analysis of an RC building with exterior partially infilled wall asim99 1 6,825 03-01-2017, 04:02 PM
Last Post: pezhmankhan
  Retrofitting steel special moment frame using ADAS metallic yielding dampers TAFATNEB 0 5,152 12-28-2014, 08:45 AM
  Evaluation of Egyptian code provisions for seismic design of moment-resisting-frame m TAFATNEB 0 5,218 09-05-2014, 02:03 PM
  Progressive Collapse of Multi-Storey Buildings due to Sudden Column Loss –Part II: Ap TAFATNEB 0 5,102 05-09-2014, 02:00 PM
  Retrofit Methods to Mitigate Progressive Collapse TAFATNEB 0 4,982 05-09-2014, 11:44 AM
  Progressive Collapse of Bridgesβ€”As pects of Analysis and Design TAFATNEB 0 4,514 05-02-2014, 09:02 AM
