Civil Engineering Association eBooks Journals, Papers and Presentations A necessary modification for the finite element analysis of cracked members detection
 asim99
User ID: 9774
Threads: 476
Likes: 6,384 in 594 posts
Given Likes: 377
04-24-2013, 11:56 PM
A necessary modification for the finite element analysis of cracked members detection, construction, and justification
Author: A. Ranjbaran, H. Rousta, M. O. Ranjbaran, M. A. Ranjbaran, M. Hashemi, M. T. Moravej | Size: 362 KB | Format: PDF | Quality: Unspecified | Publisher: Springer | Year: 2013 | pages: 10
The finite element analysis of cracked beam-like members is investigated. Through concise formulation,
computer implementation, and numerical experiment, the necessity for a paramount modification in
the governing differential equation is detected. In the course of numerical analysis, physical consideration,
and mathematical theory, the structure of the modification and its relation with the member geometry and
crack parameters is constructed and justified. Several new chain rules for use in the application of the method
of weighted residual to differential equations containing the derivatives of the Dirac’s delta distribution is
proposed. Through analysis of typical examples and comparison of the results with that of the others, the
accuracy, efficiency and robustness of the work are verified.
[-] The following 5 users Like asim99's post:5 users Like asim99's post
  • kowheng, devilmaycry, malc, Dell_Brett, civilphongvan
  ConPrimer-2 Finite Element emmi 0 5,143 03-27-2015, 12:59 AM
Last Post: emmi
  Dynamic Finite-Element Analysis of Jointed Concrete Pavements TAFATNEB 0 5,129 03-31-2014, 10:46 PM
  FLEXURAL BEHAVIOR OF REINFORCED CONCRETE BEAMS USING FINITE ELEMENT ANALYSIS (ELASTIC TAFATNEB 0 5,083 03-31-2014, 10:22 PM
  III - 1 FINITE ELEMENT ANALYSIS OF CONFINED CONCRETE COLUMNS TAFATNEB 0 4,131 03-31-2014, 10:11 PM
  FINITE ELEMENT ANALYSIS OF BASE ISOLATED BUILDINGS SUBJECTED TO EARTHQUAKE LOADS TAFATNEB 1 5,839 11-20-2013, 07:25 AM
  A Framework for 3D Finite Element Analysis of Lateral Pile System Response asim99 0 4,273 04-27-2013, 09:53 PM
  Detection and assessment of damage in 2D structures using measured modal response arshiakh 0 3,708 04-24-2013, 07:03 PM
Last Post: arshiakh
