Civil Engineering Association eBooks Journals, Papers and Presentations Minimum Foundation Mass for Vibration Control (W/ Discussion & Closure)
 asim99
User ID: 9774
Threads: 461
Likes: 6,384 in 594 posts
Given Likes: 377
04-24-2013, 11:51 PM
Author: A. J. Anyaegbunam, | Size: 246 KB | Format: PDF | Quality: Unspecified | Publisher: ASCE | Year: 2011 | pages: 9
This note utilizes the analog models of forced vibration to express the mass of foundation block in terms of damping ratio and
thereafter obtains the expression for the minimum foundation mass required to limit vertical machine vibration amplitude to a prescribed
limit. The resulting formula, which accounts for internal damping, is constrained by the limitations of the original analog solutions.
Moreover, formulas are derived for determining the damping ratio for conditions different from optimum that enable the evaluation of the
nonoptimum foundation mass required to limit vibration. Since the ideal optimum solution may not be practical, an expression has been
derived for the best nonoptimum foundation mass. The method presented in this note is believed to be easier to implement and to yield
smaller foundation blocks than the existing traditional method, and thus will enable cheaper machine foundations to be constructed. It is
believed that the proposed optimal solution may lead to the near elimination of machine vibration nuisance produced by high-frequency
machines during operation
  â€¢ usman, kowheng, sysrq, shadabg, PinkPant, malc, Dell_Brett, fer962933
  3D Periodic Foundation-based Structural Vibration Isolation TAFATNEB 0 4,487 08-11-2014, 01:51 PM
  Practical Methods for Vibration Control of Industrial Equipment TAFATNEB 0 4,316 08-11-2014, 01:38 PM
  Dynamic Stiffness and Damping of a Shallow Foundation from Forced Vibration of a Fiel TAFATNEB 0 3,916 08-11-2014, 10:20 AM
  Journal of Vibration and Control - Designing optimal multiple tuned mass dampers lisine 0 5,017 03-06-2012, 09:24 AM
