Civil Engineering Association eBooks Journals, Papers and Presentations Slenderness ratio of main members between interconnectors of built-up compression mem
 asim99
User ID: 9774
Threads: 461
Likes: 6,384 in 594 posts
Given Likes: 377
04-05-2013, 03:40 AM
Slenderness ratio of main members between interconnectors of built-up compression members
Author: Murray C. Temple and Ghada M. Elmahdy | Size: 583 KB | Format: PDF | Quality: Unspecified | Publisher: Canadian Journal of Civil Engineering | Year: 1996 | pages: 11
Many steel design standards, including CANICSA-S16.1-M89 "Limit states design of steel structures,"
specify maximum slenderness ratios for the individual main members between the interconnectors of built-up
compression members. Previous research on which these requirements are based is reviewed. It is shown that the
imperfection sensitivity due to coupled instabilities is measured from bifurcation critical loads. However, steel standards
are based on a compressive resistance determined for a member with an initial out-of-straightness and a suitable residual
stress pattern. It is shown that the use of an equivalent slenderness ratio equation is sufficient to predict the compressive
resistance of these built-up members. Further restrictions on the slenderness ratio of built-up members between
inter connectors are not warranted. Thus, the elimination of these requirements from S16.1-94 is justified.
[-] The following 6 users Like asim99's post:6 users Like asim99's post
  • Dell_Brett, malc, Hengki, slowet, kowheng, tluc
  Buckling of built-up compression members in the plane of the connectors asim99 2 7,330 12-12-2014, 04:39 PM
Last Post: Veggeta
  BEHAVIOUR OF STEEL SINGLE ANGLE COMPRESSION MEMBERS AXIALLY LOADED THROUGH ONE LEG asim99 1 5,415 10-15-2014, 11:00 PM
Last Post: KhaLed-S.E
  Design of Cold Formed Steel Unequel Angle Compression Members darkdkay 2 7,244 10-15-2014, 10:51 PM
  Equivalent slenderness ratio for built-up members asim99 0 4,200 04-05-2013, 03:36 AM
  Design Rules of Built‐Up Members in Load and Resistance Factor Design asim99 0 4,207 04-03-2013, 04:22 PM
