Civil Engineering Association eBooks Journals, Papers and Presentations Challenges in the computation of lower-bound buckling loads for tanks under wind pres
 asim99
User ID: 9774
Threads: 461
Likes: 6,384 in 594 posts
Given Likes: 377
04-02-2013, 11:39 PM
Challenges in the computation of lower-bound buckling loads for tanks under wind pressures
Author: Eduardo M. Sosa, Luis A. Godoy | Size: 728 KB | Format: PDF | Quality: Unspecified | Publisher: Elsevier | Year: 2010 | pages: 11
This paper reports on the implementation of a lower-bound approach for the buckling of imperfection-sensitive shells using general purpose finite element codes. The stability of cylindrical steel tanks under wind pressure is evaluated for two tank configurations: conical roof tanks and open top tanks. For both tank configurations, several geometric relations are considered in order to find the variation of the knock-down factor as the geometry changes. The reduced energy method is implemented to compute a lower-bound for critical wind pressures and the results are compared with the static non-linear analysis carried out on the same models. An alternative way to implement the reduced energy method is presented to improve the results obtained with the proposed methodology
[-] The following 6 users Like asim99's post:6 users Like asim99's post
  â€¢ Dell_Brett, slowet, kowheng, warbeast, jcbv, malc
  Influence of diagonal braces in RCC multi-storied frames under wind loads: A case stu TAFATNEB 0 4,181 11-25-2013, 04:36 PM
  Wind pressures and buckling of cylindrical steel tanks with a conical roof asim99 0 4,052 04-02-2013, 11:42 PM
  A reduced stiffness approach for the buckling of open cylindrical tanks under wind lo asim99 0 4,331 04-02-2013, 11:32 PM
  Investigation on Buckling Behavior of Cylindrical Liquid Storage Tanks Under Seismic mybest 0 3,731 03-29-2013, 12:19 PM
Last Post: mybest
  Computation of Wind Flow around a Tall Building and the Large--Scale Vortex Structure asim99 0 4,367 12-31-2012, 02:09 AM
  BUCKLING OF ABOVEGROUND STORAGE TANKS WITH CONICAL ROOF - Paper asim99 0 3,771 11-27-2012, 04:10 PM
  e-Analysis of High-Rise Buildings Subjected to Wind Loads ivanveliki 1 6,595 01-29-2012, 07:07 AM
Last Post: kvtasp
