Civil Engineering Association eBooks Journals, Papers and Presentations Geostatistical Analysis of Spatial Variability of Rainfall and Optimal Design of a Ra
 asim99
User ID: 9774
Threads: 461
Likes: 6,384 in 594 posts
Given Likes: 377
03-27-2013, 04:22 AM
Geostatistical Analysis of Spatial Variability of Rainfall and Optimal Design of a Rain Gauge Network
Author: DIMITRIS M. PAPAMICHAIL and IRINI G. METAXA | Size: 1.13 MB | Format: PDF | Quality: Unspecified | Publisher: Kluwer Academic Publishers | Year: 1996 | pages: 21
Kriging is a geostatistical estimation technique for regionalized variables that exhibit an
autocorrelation structure. Such a structure can be described by a semivariogram of the observed data.
The punctual&Aging estimate at any point is a weighted average of the data, where the weights are
determined by using the semivariogram and an assumed drift, or lack of drift, in the data. The kriging
algorithm, based on unbiased and minimum-variance estimates, involves a linear system of equations
to calculate the weights. Kriging is applied in an attempt to describe the spatial variability of rainfall
data over a geographical region in northern Greece. Monthly rainfall data of January and June 1987
have been taken from 20 measurement stations throughout the above area. The rainfall data are used
to compute semivariograms for each month. The resulting semivariograms are anisotropic and fitted
by linear and spherical models. Kriging estimates of rainfall and standard deviation were made at
90 locations covering the study area in a rectangular grid and the results used to plot contour maps
of rainfall and contour maps of kriging standard deviation. Verification of the kriging estimates of
rainfall are made by removing known data points and kriging an estimate at the same location. This
verification is known as the jacknifing technique. Kriging errors, a by-product of the calculations,
can then be used to give confidence intervals of the resulting estimates. The acceptable results of the
verification procedure demonstrated that geostatistics can be used to describe the spatial variability
of rainfall. Finally, it is shown how the property of kriging variance depends on the structure and
the geometric configuration of the data points and the point to be estimated can also be used for the
optimal design of the rain gauge network in an area
[-] The following 2 users Like asim99's post:2 users Like asim99's post
  β€’ ska51, kowheng
  A comparison of geostatistical procedures for spatial analysis of precipitation in mo arshiakh 0 3,837 04-25-2013, 07:31 PM
Last Post: arshiakh
  Multivariate geostatistical trend detection and network evaluation of space-time acid arshiakh 0 3,532 04-08-2013, 07:33 PM
Last Post: arshiakh
  A simple approach for improving spatial interpolation of rainfall using ANN arshiakh 0 4,078 04-08-2013, 06:33 PM
Last Post: arshiakh
  Evaluation of Rainfall Networks Using Entropy - by P F Krstanovic asim99 3 6,869 04-08-2013, 06:29 PM
Last Post: arshiakh
  Spatial and temporal scales in rainfall analysis β€” Some aspects and future perspectiv arshiakh 0 3,802 04-08-2013, 06:23 PM
Last Post: arshiakh
  Geostatistical Space–Time Models: A Review arshiakh 0 3,916 04-08-2013, 06:20 PM
Last Post: arshiakh
  A geostatistical approach for areal rainfall statistics assessment arshiakh 0 3,544 04-08-2013, 06:09 PM
Last Post: arshiakh
